IC pump activation...
Old Aug 14, 2013 | 11:34 PM
marcmaddox's Avatar
2005 E55 AMG, 2012 GL550, 2000 Ford Lightning, 2005 Chevy Silverado 2500HD
Discovered a little trick today on my 05 E55. It's seems there is a lot of issue with how and when the IC pump actually turns on. I stumbled upon this by accident and spent a couple days confirming its validity. I can make my IC pump pump turn on at anytime by simply doing a quick throttle stab to wide open. This even works on a cold startup or at any engine temp. As soon as the Computer sees TPS voltage go to WOT value it energizes the pump and it appears that once energized, it will not turn off until the ignition is switched off.
If your conserved about revving a cold engine (and in my opinion, you should be), don't worry. As long as your throttle jab is quick the engine won't even hit 2000 rpm.
I think this may be useful for some. Especially in a drag race situation where extended and constant IC circulation is desired.
Anyway, I've never seen this mentioned and thought some might find it useful.
Note: I have seen that if the coolant temp is high enough, like after a heat soak on a hot day, the pump will turn on in ignition position 2. But it will not if the temp is not at that predetermined level. This is a way to manually turn it on at any temp below that.
Old Aug 15, 2013 | 04:08 AM
thunderclaps's Avatar
E55 AMG, 04STI, 07GTI, 05 HAYABUSA, 05 GSX1000
nice.
Old Aug 15, 2013 | 09:00 AM
cij911's Avatar
one car at a time
Very interesting find. I have my pump hard wired right now, but will try to switch back this weekend and test. (I have a split cooling setup now with a small radiator in the engine bay, so t will be easy to tell I this is true.)
Old Aug 15, 2013 | 09:05 AM
Solo Man's Avatar
E55 AMG
That's one way to do it it...
I just wired mine to continuously run while the key is on.
Old Aug 15, 2013 | 10:58 AM
3BNick's Avatar
2006 E55
This. I never have to worry about my pump switching on again.
Old Aug 15, 2013 | 11:06 AM
JoeNobody's Avatar
Mercedes
Old Aug 15, 2013 | 11:16 AM
marcmaddox's Avatar
Originally Posted by jonkean
Eurocharged can now tune the ECU to keep the IC pump always on.
That's interesting. I was told by OE tuning that it couldn't be done with a tune.
I kinda thought it was BS.
Old Aug 15, 2013 | 02:38 PM
taurran's Avatar
04 E55 AMG, 03 350z Track Built/Single Turbo
Guessing there's no how-to on how to do this? I have the bumper and HE off now for an install and coolant flush, and it might be an opportune time to accomplish it.
Old Aug 15, 2013 | 05:13 PM
Solo Man's Avatar
E55 AMG
Matter of fact there is, I used it to do mine. Let me see if I can find it again
Found it: https://mbworld.org/forums/w211-amg/...nger-prep.html
He shows the wire to tap into in the bottom of the first post.
Old Aug 16, 2013 | 09:26 AM
JoeNobody's Avatar
Mercedes
Old Aug 16, 2013 | 10:19 AM
taurran's Avatar
Thanks! IT seems most of the work is done from the top, so I'll probably wait until I do the split cooling mod.
