Loud groan from steering when turning left, reservoir is full.
Old Aug 15, 2013 | 12:03 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
I had this happen once or twice a couple months back but it seems to be happening more often the last couple weeks. When I turn left, and only left just off center I get a groaning like sound for the first 1/4 turn of the wheel or so. Never turning right. The reservoir is full and I can't see anything obviously wrong when peeking around. Seems to happen after being parked or stopped and running for a while. Just hit 60K miles.
Is there anything common this may be? Hoping to pinpoint it and get it fixed before it develops into a real problem.
Old Aug 15, 2013 | 08:44 AM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
maybe pump going bad
Old Aug 15, 2013 | 09:49 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Try replacing the fluid. I replace PS fluid every 20K miles along with the transmission fluid. The stuff does break down over time.
Old Aug 15, 2013 | 10:47 AM
MOTOJAE's Avatar
2002 CLK55
Replace the fluid res.there is a filter inside that gets dirty causing poor flow. ... Much cheaper than the pump, very common for noise issues.
Old Aug 15, 2013 | 11:39 AM
novae500's Avatar
W211
i had that problem during the winter and the fluid was dark honey. When it should be a greenish/clear color. replaced the black reservoir that included filter and all is well. Had 65k on it when getting the noise.
Old Aug 15, 2013 | 05:36 PM
AgSilver's Avatar
Old Aug 15, 2013 | 07:03 PM
berti_00's Avatar
2016 Cls63s AMG
replace the reservoir too.... i did it for a maintenance reason, because they have filters inside to that aren't replaceable and have to replace the whole reservoir
Old Aug 15, 2013 | 07:04 PM
KrazyKorean's Avatar
2003 E55 AMG
Does anyone have the part number for it?
Old Aug 15, 2013 | 07:11 PM
berti_00's Avatar
2016 Cls63s AMG
part number for what? the reservoir... just go to the dealer and get it its like 40 bucks
Old Aug 15, 2013 | 07:47 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
FYI the original ps fluid was yellow in color but MB "updated" the fluid to the pentosin chf11s to reduce noise (green color). The filter may be clogged as well. I would flush the system as best as possible with chf11s and replace the resivour as well.
Old Aug 16, 2013 | 02:27 AM
BBBSS's Avatar
I'll be picking up a new reservoir and fluid. Probably gonna look around to see if I can find the fluid online cheaper. Is the Pentosin backwards compatible with the old stuff? Being an 03 I'm guessing I have the old stuff.
