DIY Retrofit for Automatic Trunk Closer.
-Nigel
-Nigel
I have attached a PDF of how to install the trunk closer on W211. This was one of the more challenging retrofits I had to do simply because there wasn't much documented in the WIS and I purchased some used parts and the harness they sent was completely wrong so that had me confused for a while.
This can also serve as a harness replacement guide for those that already have the closer and had issues with their harness getting cut. By the way, I have a spare harness (somehow, I ordered two) if anyone else wants to attempt this.
Had to break it down into 4 pdfs due to file size limitations. It probably messed up the numbering also for the steps ..
In any event, I installed the system this weekend and it is working great. I never could have done it without your efforts.
