Need Help... Where to buy Forged/Pistons?????
Old Aug 29, 2013 | 03:42 PM
SvenniTiger's Avatar
RR Sport S/C - BMW 745I - BMW M5
hi there guys
i have a e55 amg 03'
can you guys tell me where to buy either oem or forged pistons for my engine?
and what u recommend? and what prices there are?
thanks
Svenni
Old Aug 29, 2013 | 04:04 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
For the stock aluminum bore, you can get some from Mahle, Mercedes (OEM SLR, made by Mahle), or Weistec. Either set will cost over $2000 USD. If your block is damaged and you are installing iron sleeves, then there re a number of manufacturers who can make a set for you.
Old Aug 29, 2013 | 04:09 PM
AMG E Power's Avatar
E55 amg
@sir-boost-a-lot, did u get ur weistec blower done in at c2 in Tampa ?
Just curious being I just heard there was a e55 roaming the streets of Tampa with a upgraded blower.
Old Aug 29, 2013 | 04:15 PM
can you send me some links?
iron sleeves where do i get them? i dont know if my block is damaged. i havent checkd it
Old Aug 29, 2013 | 04:28 PM
Nah my E55 never ran with the blower on it. I had it mocked up with the built engine but switched plans and am going to build a CLS instead. I live in Orlando and never heard of C2...
Sorry Tiger, I don't have any links, call Mahle. I think they're a custom order but they're a lot closer to you than to me. Figure out if your bore is damaged first, then you'll be headed in the right direction in regards to what pistons you'll need.
Old Aug 29, 2013 | 04:54 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Do a leak-down test right away .
I had the Darton steel sleeves blocks developed for our engines and also worked with Mahle to make the customer pistons for the my engine. We usually keep Mahle pistons in stock for stock size bore but depending on if you run a Steel bore, Nickasil bore or stock Alusil bore will denote the piston coating and rings needed. PM me if you need help.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 1, 2013 | 11:00 AM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Woessner Germany. ~300$/piece.
Old Sep 2, 2013 | 09:45 PM
Are they as good as oem?
