Just did coilover conversion on my e55
Why have some people gone with E320 arms and you went with E500? The stock rear arms can't be used? I'm confused now .... I want to do this mod once I get her back but I want to buy the right parts the first time around. Also you replaced your bushings with OEM bushings or did you go with aftermarket?
Thanks!
Post pictures please when you have time
Rear Lower Control Arm
Mercedes E Class...(E320 rear RH,LH thrust arm),(Rear RH,LH,E320,spring),(E320 Rear RH,LH track arm)........
Rear Upper Control Arm
Mercedes E Class........(E320 rear ,camber strut guide, LH,RH) and ( E320 rear tension rod guide RH,LH)
https://mbworld.org/forums/e-class-w211/448921-w211-airmatic-coilover-conversion-done.html
People are way too quick to judge coilovers on any car, yet 99% of the time do not fully understand the dynamics of how a suspension works to deliver a proper ride.
