Tcu problems
Just picked up a 2003 E55from a friend of which already had a tcu tune in it, was tapping limiter at 2nd-3rd shift. Sent tcu back for retune upon receiving tcu back in my possession and installing back into car I got a check engine light, abs malfunction, and ESP malfunction the car will not shift out of first and I cannot choose comfort, sports or manual mode. Sent tcu back and was informed wrong program was initially loaded however they have gauranteed the correct program is now loaded. Received the tcu back again and installed back into car with same results as before. Any advice on how to find a resolution for this problem would be greatly appreciated. Been without car for a month and out $100in shipping costs for tcu tuning.
E/C deals professionally with all kind of tunes,, you should to contact to them quickly, they are soo helpFUL,,
did you try to diagnose your car, you may have something else to follow it...!?!
ZAYED,,
Loading an original file will solve your prob, except in case the hardware is damaged.
This may be indeed your case: tuning that control unit usually involves de-soldering and soldering back the 44 pin chip in it.
its enough that one pin is not contacting correctly or broken and you are set like being without the module at all..
in that case, just find somewhere an original module from a car like yours and you 'll be OK.
I really wonder whats the problem there? I would send it back and have them ship you a replacement TCU with a tune. They seem to have them tuned in stock.
They have maybe killed yours so its their fault.
I was expecting your call this weekend, but did not hear anything.
Let me know
Craig
Thanks again everyone
nice to know you are happy now .
would not look for more than that.. you've been lucky enough for having it sorted out this way
