any1 have kleeman with sec cat and reso
Blown 208 55 amg, 211 55 amg
Is anyone running kleemann headers with secondary cats and resonators still attached? I am wanting to install kleemann headers for both sound and performance but i dont want a drone all the time only when i kick it down or in high rpms 3k above
PLATINUM SPONSOR
If you have the cats, you will not have drone. You can always keep your resonator as well but kleeman with cats is a good sounding ride.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Leave your resonator on and you will have no problems. I'm running the set up you described and the sound is wonderful especially at WOT. You will get ZERO drone as long as the resonator is still on..
