Need Help re Gas Smell
Old Sep 10, 2013 | 05:57 PM
Coalman's Avatar
2003 E55 K1
Unhappy Need Help re Gas Smell
My 2003 E55 has developed a strong gas smell in rear. Buckhead dealer in Atlanta says that it is a vent at the top of the tank that is not closing and that it will cost $2,600 to replace the tank!! In late 2010, dealer here in Pittsburgh replaced sender units on right and left side and did something with seals but never said anything about vents. Does any of this make sense to you guys and if so what are my options other than spending $2,600?
Old Sep 10, 2013 | 06:32 PM
statepkt's Avatar
2007 E63
Use the forum search function. There is a common fuel leak in the rear of the E55 and E63s. You should be able to verify the if it is the common fuel leak or not yourself
