acceleration issue 2004 e55 amg
Old Sep 22, 2013 | 05:37 AM
tw457's Avatar
2004 E55 AMG Obsidian Black, 2005 C55 AMG Obsidian Black
I just purchased an 04 e55 with 94k on it. Its fast but my brother has the same year of car and his is FAST like throw you in the seat fast. The one I bought has a different exhaust note but does not appear to be aftermarket and the car is fast but but not fast like his and his is stock except for the sl55 driver snorkel tube which I have too. When you get on it sometimes it feels like it hesitates but I can push the pedal to the floor and it starts to go but on his I have never been close to florri g the pedal because it is GONE at the halfway press. If anyone knows what this could be I'd appreciate it. Other forums I read made it sound like the I/c pump causes similar problems. I have it going to the dealer for a diagnostic on Tuesday the 25th so I just want to know what to expect. Also it says it needs a service F if that helps
Old Sep 22, 2013 | 08:02 AM
vioilio's Avatar
2003 E55 AMG
https://mbworld.org/forums/w211-amg/...set-works.html
You are Welcome!
Old Sep 22, 2013 | 08:57 AM
Firechaser's Avatar
2008 GL550
You could have a bad intercooler pump too causing high IAT's...which will result in the ECM pulling a bunch of timing. That can most definitely make your car feel a lot slower too.
Old Sep 22, 2013 | 01:04 PM
tw457's Avatar
I will try this ecu reset I also appreciate your fast responses. Even though I don't know any of you well YET still makes me feel warm inside :-) I will still get the diagnostic and report my findings just to see what I got good or bad. The exhaust if its not after mark may be a leak so I want to rule that out
Old Sep 22, 2013 | 02:06 PM
dllhg's Avatar
2014 cls63 a amg. 2018 AMG GTR
X2 on IC pump. I happen to have the newer version Bosch pump on hand you can have for $80 shipped if interested. Cost you around 120 shipped otherwise. Has less than 1000 miles on it. I needed a bigger ump for my Killer Chiller so I barely used it. My old stocker would shut down the SC because the pump wasnt working and that robs all your power.
PM me if interested.
Old Sep 22, 2013 | 02:41 PM
HGOTBOOST's Avatar
E55 AMG
Most likely, Its the IC pump.
Old Sep 23, 2013 | 10:04 AM
tw457's Avatar
I did the ecu reset and it did help a lot for shift points but I can still press the pedal a little too far before seeing any action and my brothers e55 is just a little bit too hot for me to accept that everything is OK. His is stock and since I drove both he would easily smoke me.
In other news I got a pretty nice car.
All the regular options plus
*keyless go
*electric rear sunshide
*lighting package
*comfort package
*distronic cruise control
*keyless go
*Automatic trunk closer
*heated seats
*cooled seats
*Brilliant silver metallic on charcoal
And best of all no panoramic roof that's a horrible fix if it brakes so I'm glad I don't have one.
The distronic is pretty cool though
I got a really good deal on this car. The guy I bought it from didn't even know what he had
And he thought it was fast and I don't think he even knew something was wrong. I knew right away how fast it should be though
Old Sep 24, 2013 | 10:45 AM
ArmoE55's Avatar
2006 E55
Are you not reading what people are posting?
Did you check your IC Pump to see if it's failing or dead? A dead IC pump will not only heatsoak the hell out of your car and pull timing, but it'll shut the blower off, too, and your car will feel like a dog compared to your brother's car.
Check the IC pump or better yet , replace it ASAP with the CM30 or Bosch 010. With 94K miles and if stock pump, I can almost guarantee it's dead or not functioning properly.
Old Sep 24, 2013 | 01:38 PM
tw457's Avatar
I took the car to Mercedes today to have them change the i/c pump and run a diagnostic.
Old Sep 24, 2013 | 02:02 PM
tw457's Avatar
i need a johnson cm30 intercooler pump, if anyone has paypal and can overnight me this part let me know asap
Old Sep 24, 2013 | 02:21 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Why not just order a Bosch 010 from an online site?
Old Sep 24, 2013 | 02:39 PM
tw457's Avatar
is the bosh 10 better than the cm30? what pump does the dealer use for this? how much can i expect to pay if i have the dealer do the install?
Old Sep 24, 2013 | 02:45 PM
SilverStrk's Avatar
05 E55, 07 ML500
This.... Better yet if it's at the dealer have "them" install the 010... It is better than the cm30..
Old Sep 24, 2013 | 03:18 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Bosch 010 is better and cheaper than the CM30.
Old Sep 24, 2013 | 05:29 PM
tw457's Avatar
Does anyone know what kind of pump the dealer will have to replace mine if I cannot get a Bosch fast enough?
Old Sep 24, 2013 | 05:30 PM
tw457's Avatar
Also who knows how much a service F costs? And what is involved in a service F
