still missing power after I/C replacement
If that is ruled out, you could have a plugged fuel filter/failing pumps(if they were never replaced).Also, lazy primary oxygen sensors, old spark plugs, stretched supercharger belt, worn/slipping supercharger clutch pulley. All of those could contribute to a decrease in power.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
