Racing Brake Rotors
Old Oct 7, 2013 | 04:52 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Racing Brake Rotors
Anybody use their light weight rotors on the street ?
Old Oct 7, 2013 | 07:55 PM
320 dreamer's Avatar
2003 porsche 996 turbo
i had them on my 32 and they were awesome. remember you cant use ceramic pads with them a hawk hps pad is preferred. brinell hardness is a 277
Old Oct 8, 2013 | 01:20 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Improves handling, braking. Also by reducing rotational mass, about the equivalent of a 40HP increase.
It has been more than 5000 miles since new with EBC Reds and no problems with many hard applications above 110 MPH.
Old Oct 8, 2013 | 02:54 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
40HP
40...
where did you get that number...
if that was try we should all do rotors.....
Old Oct 8, 2013 | 03:18 PM
kompressede's Avatar
Sold - 05' E55
^ Thats like 10hp per rotor? ?
Old Oct 8, 2013 | 03:42 PM
Toadster's Avatar
2005 E55 AMG
$1300 just for the fronts - yikes, you can pull the spare tire and cut-out your resonator to save more weight
Old Oct 8, 2013 | 03:49 PM
Extreme Dimensions's Avatar
Former Vendor of MBWorld
Too Many To List
That's a big HP number to toss around, especially for for a non power mod... While rotational mass does make a big impact, I'd like to see a source for this number...
Old Oct 8, 2013 | 03:50 PM
Too Many To List
That's non rotational mass. also, its not just about weight. Stopping power FTW lol.
PS. Great sig pic
Old Oct 8, 2013 | 04:54 PM
Toadster's Avatar
2005 E55 AMG
PS. Great sig pic
yes, I totally agree, unsprung weight is a big difference on the corners - how do those rotors stop better than the stock ones? they're just lighter - correct?
and yes, I like my sig pic too
Old Oct 8, 2013 | 06:02 PM
Too Many To List
Yes, they are lighter, as well as being made of a harder iron than the OEM, different vane design if i recall, etc.. if you go into their site it gets a bit more in depth in regards to their advantages
Old Oct 9, 2013 | 05:05 AM
AgSilver's Avatar
Rotational mass, also known as kinetic energy. It takes less energy to spin up and therefore less energy to dissipate under braking.
Old Oct 9, 2013 | 05:31 AM
AgSilver's Avatar
Originally Posted by sunil517
40...
It is a calculation which can be applied to any rotational mass. For example; look at the equivalent HP gains that are achieved by the replacement of engine crank pulleys with lightweight units as offered by various tuners. Usually in the range of a 10HP equivalence. Now consider the effect of a reduction of 40 LBS of rotational mass. This is partly why most exotics such as Ferrari, MB SLS, Porsche, to name just a few, all offer carbon rotors which save another 40 LBS or about 80 LBS. The MB SLS even utilizes a carbon fiber drive shaft (as do I) to reduce rotational mass. Years ago an acquaintance of mine said "add horsepower and go faster on the straightaways . . . add lightness and go faster everywhere". His name was Colin Chapman.
Old Oct 9, 2013 | 02:57 PM
RacingBrake's Avatar
CLS550
Learn more about the advantage on light weight rotors from "ML63"'s latest evaluation on his ML63 wit RacingBrake's two piece rotors (front and rear) installed.
https://mbworld.org/forums/5797439-post70.html
Under the thread title: World's First: RacingBrake 2-Piece Brake Rotors ...
