Pulley 180
I HAD the same pulley once and it of course had issues with bad balancing. It's now just a piece of metal laying in my garage. I made mention to the comp that I got it from and it was my fault.
With pain , I have to write words of truth .
After a few months , and the help of many kind people . Car drives perfectly . If the EC hopes that in Poland there are no good lawyers . Their problem.
Contact zero . Engine after using their pulley has been tested . Pulley as well.
Each item is described in the expert .
I bought a new engine. old has been secured .
Someone will say : vendor is holy - that's not true .
What I would like to write:
Thank you Shardul . Great pulley . It is balanced , works perfectly. Knowledge and willingness to help on a global level .
Many, many great people on this forum.
Tony and Craig from Bi - Performance helped to find another fault why the car does not drive .
So wonderful injectors Bosch ev14 from the EC. I note the fuel pressure checked . They went to the assessment of an expert. Injectors do not work correctly . another time lost .
With Bosch ev14 car stops going from 5500rpm AFR drop it 9-9.5 .
Lots of money spent, time wasted .
The effect of EC 518HP/820Nm peak . Shardul + Bi- Performance 643HP/861Nm .
Thank you to everyone who helped .
I'm sorry that it happened , but it is the truth
#32
X172
Shardul helped me dodge a bullet recently by explaining the differences between the EC crank pulley and other options. I'd incorrectly assumed that it was built from a stock MBZ harmonic balancer.
It's not.
That was a non-starter for me. I wanted a solution based on a properly dampened crank pulley.... Shardul was able to get me into a better quality 172mm ASP (which IS built off an MBZ core) for a very competitive price.
-G
#41
180 pulley and wrap kit(shardul), K&N filters, tb82, Kleemann headers, heat exchanger(EC), trunk tank kit (no ice), ECU BIP tune (very safe, it will be corrected.).
#42
Good job
#44
#47
Location: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
Do you have a special intake setup or anything? I have a 180/82mm/longtube setup and my Supercharger doesn't scream like that. I WANT THAT
Nice runs, and from the short time I've been on this board, I've already learned that Shardul and Craig are just top notch people to deal with. Great job helping this guy out!
#48
#50
Blown 208 55 amg, 211 55 amg
Did the pulley supplier correct this issue on their new pulleys their selling? Reason I ask I have the same pulley same problems...I spoke to the seller they where more than helpful and reasonable just simply asked for photos and told be no problem send it back they would take a look at it and correct the problem aka send me a replacement. Now, that's great customer service imho! I haven't found time to take it off yet however hopefully this week
