Pics of a stock E55 fuel pump anyone, help needed?
Old Oct 11, 2013 | 09:30 AM
chawkins2001's Avatar
2006 E55 AMG
Question Pics of a stock E55 fuel pump anyone, help needed?
If you have a couple pics of the top and bottom of the stock e55 fuel pump, could you post them up? I have gone through 4 pumps in a year running e85, and are going to a different style pump.
Note to the E85 guys, dont run the Aeromotive Stealth 340lph pumps, part number 11140. The e85 will strip the coating off the impellers and destroy the brushes causing the pump to get clogged. The pumps will work harder, ultimately failing. I learned the hard way after been told by Aeromotive that theirs is compatible, it is not.
After doing some research, these are the pumps compatible for E85:
http://www.lethalperformance.com/2013-2014-shelby-5-8-l-gt500/fuel-delivery-1/fuel-pumps-1/aem/aem-320lph-high-flow-in-tank-fuel-pump-e85.html
http://www.lethalperformance.com/2013-2014-shelby-5-8-l-gt500/fuel-delivery-1/fuel-pumps-1/divisionx-1/divisionx-stryker-340lph-fuel-pump.html
http://www.lethalperformance.com/2013-2014-shelby-5-8-l-gt500/fuel-delivery-1/fuel-pumps-1/walbro-1/walbro-465-lph-high-pressure-fuel-pump.html
Old Oct 11, 2013 | 09:42 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
Maybe these?
https://mbworld.org/forums/5554847-post19.html
https://mbworld.org/forums/engine-pe...condition.html
Old Oct 11, 2013 | 11:01 AM
GunMoto's Avatar
EG8 | E46 | W211
These are all I could find for now in the baskets; none of the actual OEM pump by itself.
Old Oct 11, 2013 | 11:37 AM
vioilio's Avatar
2003 E55 AMG
pm sent! My pumps are out so I can send all the pictures you want!
Old Oct 11, 2013 | 11:40 AM
2006 E55 AMG
Shweet, it looks like the Stryker 340lph pumps might be the answer in my first post.
Old Oct 11, 2013 | 01:54 PM
2006 E55 AMG
Thanks Vioilio, you are the man:
Old Oct 11, 2013 | 03:20 PM
vioilio's Avatar
2003 E55 AMG
Anytime!
Old Oct 11, 2013 | 04:01 PM
rockthemullet's Avatar
2005 Mercedes E55 AMG
Ah, looks like you made a post.
Something to note, DivisionX was formerly a company called Fore. I'm not sure why they changed their name but they've been providing quality fuel components to the Cobra guys for years.
I'll ask around on the AEM. There's is also the Deutchwerks DW300 that has been performing well in E85.
If you want to get really crazy, you can run your stockers into an external booster pump. The single pump out of the Bugatti Veyron is cheap and it'll flow enough for 900whp by itself. It's a screw type so noise is next to nothing.
Nice pics, vioilio!
Old Oct 11, 2013 | 05:34 PM
2006 E55 AMG
I went with division x 340 lph pumps and their fuel filter with the stainless 10 micro filter. Going to mount tbe filter inline and throw the stock filter in the garbage. It will be easier filter replacement when the time comes. I have a couple more pics to post up of the stock fuel pump with measurements.
Fore make sick fuel hats and rails ftw.
Old Oct 11, 2013 | 10:07 PM
marcmaddox's Avatar
2005 E55 AMG, 2012 GL550, 2000 Ford Lightning, 2005 Chevy Silverado 2500HD
I'm curious, can you simply remove the stock filter without negatively effecting the regulator? I haven't seen the 55's pump assembly out of the tank. It seems (from pictures I've seen) that the filter is a mutual part of the regulator.
Thanks!
Old Oct 12, 2013 | 11:04 AM
2006 E55 AMG
I have not tried it either but will look at it and take pics monday.
Old Nov 12, 2014 | 10:30 AM
BC928's Avatar
2006 E55, Various other German and ‘Murican
Any one else working around this area. Doing my research for the replacement of the pumps and filter assemblies. 82k miles with only the passenger side replaced from what I can tell from the history.
Old Mar 21, 2015 | 10:42 AM
Blk55amg's Avatar
E55 AMG
Any instruction or diy on exactly how to get the pump setup out of the fuel tank?? The baskets look pretty big. Do they detach and come out one by one?? I was told removing the fuel tank from the car is needed?? Need a little guidance.
