Ready for MIR!
Old Oct 22, 2013 | 01:50 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
The V is like the E55 where there is a filter on the fuel pumps in the tank, only in the V you have to drop the rear end and the tank to get at the pumps! There are guys who have been running E85 for a long time so the stock pumps must be ok. I have heard that you should run a tank of 93 through it every now and then though so you don't get a black gunk buildup in injectors or even pump I suppose.
I am not certain what timing guys are running but there are all different setups too so it is kind of hard to compare them. Some guys have bigger built engines, some are on bigger supercharger, some stock engine and blower. I do know my car is at 21*, it was at 22* on the dyno (on 93) but due to my coolant pump not working when I was tuning we had to take 1 degree out on the street. Another guy was running meth injection spraying a lot of it and was running 26* of timing which is what I am guessing you could probably run on E85 but I am not certain.
The one guy I did ask the other day about timing said he wasn't sure what it was set at, he said he thinks it was 22 but would have to check. That seemed low to me though.
Old Oct 22, 2013 | 02:22 PM
320 dreamer's Avatar
2003 porsche 996 turbo
Originally Posted by chawkins2001
I had 50 gallons of e85 stored in 5 gallon plastic fuel cans stored in my garage last winter. I stored the summer blend as it has the highest E85 content and actually tested E90 through my tester.
Word to the wise, dont do that, lol. The corn got very thick which you could not see through the red plastic cans. Using that method, it would take me at least 15minutes to try and get my car started when it was 50* or colder. I asked about the pumps Brian/David because not all fuel pumps are E85 compatible. I learned that over the past year by going through 4 aeromotive 340lph stealth pumps that were claimed to be E85 compatible, well they are not:
http://www.svtperformance.com/forums...tive-pump.html
The E85 fuel, and the fact that it can get thicker in the winter if the blend is not mixed correctly can cause havoc on the pumps. It corroded the black coating off the stealth pumps turbines, clogged them up and caused primature failure. Another thing you will need is a E85 specific fuel filter.
I love E85, the smell, pricing, and performance you can get out of it. There is however alot of headaches that go along with it that I hope you dont experience. If have any questions down the road, hit me up, odds are I have experienced it all on the corn.
Do you know how much timing they run in the CTS-V E85 cars?
here you go craig. all the fuel pump setup you will ever need. radium surge tank with twin or triple walbro 400 l/ph pumps. these are set up for e85 and if you run teflon coated lines the e85 will flow.
http://www.radiumauto.com/Multi-Pump...Tank-P271.aspx
Old Oct 22, 2013 | 02:40 PM
chawkins2001's Avatar
2006 E55 AMG
Those Walboro 400lph pumps are also failing prematurely when running E85. Walboro soon came out with their new 465lph pump that gets advertised as E85 compatible after the failures started to happen.
Walboro 400lph pump
http://www.lethalperformance.com/201...fuel-pump.html
Walboro 465lph pump (E85)
Old Oct 22, 2013 | 07:11 PM
ArmoE55's Avatar
2006 E55
I CAN'T WAIT FOR THIS EVENT! So many sick nasty cars going ... I'm gonna be in car heaven as a spectator
I wanna see who the overall fastest will be...I hope folks like Ahmad hit 9s...
Old Oct 22, 2013 | 07:28 PM
60nomad's Avatar
2011 CTSV auto, 06 E55 white pano, 87 Grand national, 63 split window
I am hoping that all of the guys shooting for 9's get to their goal!
Old Oct 23, 2013 | 12:10 AM
E55AMGGG04's Avatar
04 w211 E55
HAD TO COME IN HERE AND REPORT THAT BRIAN's CTS-V IS A MONSTER!!! That was incredible what I just witnessed tonight lol. That car is ridiculously fast. So much power , alot of wheel spin down low but it started moving that thing was flying! That's some awesome work bro! Had fun tonight!
Old Oct 23, 2013 | 12:12 AM
  #32
urbamworm's Avatar
Beware of the V
Old Oct 23, 2013 | 12:21 AM
  #33
blackbenzz's Avatar
haters crazy
Nice!!! Making good power. Now I need to get my hoopty together for MIR
Old Oct 23, 2013 | 11:43 AM
  #34
60nomad's Avatar
Thanks Meto, I appreciate it...fun lil focker isn't it?
45 degrees was a lil difficult to get traction...need to get used to the colder weather...I must have hit the limiter 6-7 times! lol...not good!
Originally Posted by urbamworm
Beware of the V
HURRY UP!
I am debating whether to leave Friday night or Saturday real early and and stay Sat. night? I have a 6 hour drive...what time do we start on Sat.? Peeps coming a long distance...are you guys staying around Fri. or Sat.?
Gonna post this in the other thread too.
Old Oct 23, 2013 | 11:47 AM
  #35
ArmoE55's Avatar
2006 E55
I'll only be there Sat ...
