Question regarding boost readings through Torque app
Now I've got a boost pulley on and Kleemann headers. When I'm on WOT, the boost pressure has gone no higher than 12 pounds. I was under the impression that stock was 11.8 and the pulley brough it up to 13 or so.
Is there something I'm missing there? If the numbers are true, couldn't I theoretically stack a 168 or even a 175 safely without worrying about running too lean? I was under the impression that anything over 15 pounds is a bad idea on stock injectors/rail.
Now the whole fuel filter/tank this is a different story. My tank is fine, don't get me wrong. Absolutely no problems with it. Seeing that one tank though with the completely black filter worried me too, and it's apparently no easy task just to replace the filter. Looks like you have to replace the whole unit or even the tank.
So are the readings right or are they lower than what they should be?
Basically your headers (and the deletion of your primary cats) help lower your boost while the pulley brings it back up.
What is the altitude of where you are in California? That has an impact.
FWIW, I use the Torque app as well ... when I was stock, I was seeing a max of ~10.2 - 10.5 and I'm roughly 24m above sea level. I put 408/482 when I was bone stock.
With the addition of the smaller upper pulley, I am seeing about 1psi more, with peak being roughly 11.4-11.5.
Aftermarket headers and no primaries will result in boost loss although you gain a substantial amount of power... so those numbers are likely correct given those factors.
IMHO, don't run too much boost. I think 10-11psi is the perfect spot for this car. Headers and TB are key, but I'm done with power adders...already not enough room to open her up for more than a gear or two
Either way, the most I'm going to go is stacking a 175 with the boost pulley. I've considered a Kleemann 168 for safety sake, but it *is* a difference of 1.1 pounds. Given, I don't know entirely if 1 more pound would make that much of a difference. Being safe than sorry is a big thing for me.
I saw on EC's website that normal stock boost for the 55 is 11.8. I'm guessing that's not quite right then...?
