The simple things that make a job easier
Some of you may use this but since Mb uses a ton of tough black gasket sealer on a lot of the parts, I thought I would share real quick. I know most people are not doing big gasket jobs but this is a time saver on doing valve cover gasket updates , rear main seals and oil pans.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
http://www.ebay.com/itm/Mercedes-Fly...-/121128568709
www.ultimatepd.com
It will loosen our sealant also cause it's the same sealant used.
