help
Old Nov 4, 2013 | 05:15 PM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
help
my 06 e55 sometimes the steering wheel wobbles from 45 to 60 mph and some times it does not. Can anyone get what is it from, could it be the bushings or wrapped rotors?
i have brand new tires on there and rims are straight.
thanks
Old Nov 4, 2013 | 06:16 PM
Toadster's Avatar
2005 E55 AMG
thrust bearings?
Old Nov 4, 2013 | 06:30 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
if its doing it only at certain speeds = resonant vibration, then its probably a balance issue
vibration only at certain speeds is usually a balance or tire issue
and toadster- we dont have "thrust bearings" ... you might be thinking Thrust arm bushings
Old Nov 5, 2013 | 08:00 AM
Manuyc's Avatar
thanks guys!
Old Nov 5, 2013 | 08:17 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
See if your wheels are bent.
Old Nov 5, 2013 | 09:04 AM
ArmoE55's Avatar
2006 E55
He already said his wheels are straight.
OP- Did they do an alignment and balance with the new tires?
Old Nov 5, 2013 | 09:47 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
anytime the steering wheel vibrates above 55 mph the problem is coming from the rear tires.
Old Nov 5, 2013 | 10:51 AM
rchase's Avatar
2004 E55 (sold) 2012 E350 4M
Are you running stock wheels?
Old Nov 5, 2013 | 12:16 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Those are the most flamboyant stock wheels I've ever seen!
Old Nov 5, 2013 | 12:54 PM
berti_00's Avatar
2016 Cls63s AMG
those are not it... he has the other first set on asantis
Old Nov 5, 2013 | 12:59 PM
HeissRod's Avatar
Say wha?
Old Nov 5, 2013 | 01:11 PM
rchase's Avatar
It's probably very likely it is not hub centric. You may need hub rings. If it is for sure a wheel that is built specific for Benz and is in fact hub centric the only other thing I can think would be that you need to road force the tires. The tires can still be in balance and "zero" out but what happens is one area of the tire can have too much material essentially and cause a heavy spot which while spinning would cause a vibration. What they will do is match that high spot on your tire with a low spot on the wheel. In most cases vibrations are caused by 3 or 4 things: bent wheel, out of balance, custom wheels not hub centric, road force the tires.
Old Nov 5, 2013 | 04:05 PM
W109 W211 6.2L's Avatar
2008 W463 G500, 2003 Terminator Cobra (710RWHP), 2012 S350 Bluetec, 2010 911 C4S, 2007 VRSCDX
Really?? Any car? If so thank you for sharing the knowledge!!!!
Old Nov 5, 2013 | 04:24 PM
shardul's Avatar
yes sir
next time you are at a tire shop ask them and they will say the same thing
Old Nov 5, 2013 | 04:25 PM
yes sir
Well then the shaking in my fathers w140 is from the rear accumulators. Thanks! This forum has paid dividends today
Old Nov 5, 2013 | 09:06 PM
Manuyc's Avatar
, i swapped back to the asanti's 20" with new tire
Old Nov 5, 2013 | 09:07 PM
Manuyc's Avatar
yes sir
new rear tires too Shardul
Old Nov 5, 2013 | 09:09 PM
Manuyc's Avatar
usually when its the HUB it will make a noise. So there is no noise coming from the HUB
Old Nov 5, 2013 | 09:29 PM
HeissRod's Avatar
Were they road force balanced?
Old Nov 5, 2013 | 10:35 PM
berti_00's Avatar
2016 Cls63s AMG
the vibrating could be that the car's got so much power that it wants to take off nigg aight..... girl
berti_00's Avatar
2016 Cls63s AMG
what exactly is road force balanced? never heard of it. Is it something different than the regular balance that shops do or something special
