FRONT TIRES WEARING OUT QUICKLY?!
In addition, the amount of "drop" that occurs at 68MPH is either 10mm or 15mm depending on which mode you are in. If you spend a lot of time above that speed, you can expect that your alignment numbers may be off slightly from the "static" values that you see during an alignment. Toe in particular is susceptible to changing with ride height and can really screw with your tire wear.
-G
HeissRod,
Great pic man Thanks!![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Since i bought this benz I have been using Sport trans setting/ light off on level control / light off on damping setting.
give me ur .02 on other settings if you have run them, if you dont mind that is?!
#33
It drops when I activate the level control yes, but when I hit the damping switch to SP1 it lowers more? thought that weas activated by a certain speed?
