Soooo Close it hurts!!!
11.019@126.33. Here's the videoThis was my first run of the night. Second run I tried launching a bit harder but the tires broke loose. I figured I would drop a psi and try again. when I pull into the pits I see smoke coming from under the hood
oh no. Pop the hood and coolant is leaking from the expansion tank cap. Hoping its just a bad cap and not a bad head gasket. Gonna get it checked out tomorrow, hopefully nothing serious, but it ended my hunt for 10's tonight. Hopefully I can get her out one more time before the snow flies.
Thanks sir!! I knew I would have gotten it last night, but of course something had to go wrong!! I will not give up
1.59
Yes Speedriven pressure tested and an was unable to find any leaks. It drops from 19psi to 17psi but seems to hold the pressure after that initial drop
Yep shinnies and pulled the front seat for this run. Picked up over 2mph and 2 tenths just by doing that. A harder launch would have done it, but tires spun on my second run trying to launch harder and that was all she wrote because of the coolant.
The proper cold fill level is just over top or even with the black plastic piece sticking out when you look down into the fill hole.
keep it up you'll get it.
