I purchased a used E55, last week and I'm having the initial service
performed on the car and replacing all fluids. I'm having the oil and filter changed, transmission flushed and new filter, bakes flushed and all air/cabin filter replaced. While he has it up on the rack, I'll have him check and pads and control arms. Is there anything else that I should have my shop look at?
07 E63 + 07 CLK63CAB
Would not flush the trans, drop pan replace filter drain converter if possible then refill to proper level. If unable to drain converter then do the drop pan/ filter again after a few miles.
