getting ready to do trans fluid/filter change question about filter and oil.
this is the DIY im going to be using, have a question in regards to the filter, oil and gasket.
what brands of filters are ok to use? meyle, mann, filtran, or just go with the dealer one?
want to do a complete flush, other than the MB trans fluid is there a cheaper alternative i could use?
Shell 134 ATF is approved but has mixed reviews and Valvoline Import Multi-Vehicle Full Synth ATF is the other ive been reading about.
Which do you recommend? winters get pretty cold here down to the teens and summers have been known for mid 90 temps for weeks.
also is it necessary to replace the pan gasket at 50k?
I did a flush on my E55 transmission within 2 weeks of owning my car.
I had my dad for help, who has an S55 that we had done before. We are about to do his car again(30K miles since we originally flushed it).
We used shell 134 for both of our cars and I used a mann filter but my dad used OEM and we changed the gasket both times, just because its like $8.
I would go with the OEM filter because the price change for aftermarket was not justified it was just convenient.
But the shell 134 has been great, we get it from a local distributer.. 12 quarts for $65..
PLATINUM SPONSOR
Make sure you get the fluid level exact and check it several times after you drive a while. These trannies freak over a few ounces over and under I stay with MB fluid and filter in my changes.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
i will give them a call , thanks
the dipstick tool which, one do i want?
the amazon one doesnt show if its in MM or has 20 low, and 80 high like the one below
http://www.ebay.com/itm/Mercedes-Benz-722-6-Transmission-Fluid-Dipstick-1220mm-/131058912706?pt=Motors_Automotive_Tools&hash=item1e83b84dc2&vxp=mtr
this one supposedly comes with a pdf sheet.
http://www.ebay.com/itm/Mercedes-722-6-Transmission-Fluid-Dipstick-Repair-Tool-/111226562810?pt=Motors_Automotive_Tools&hash=item19e59ea8fa&vxp=mtr
Hey what part of CT are you in?
if you need an extra hand doing the trans fluid let me know, If you aren't too far I can lend a hand...
I haven't done any tranny work but can help out and since i'm having engine issues, I will also do my trans fluid before I get my car back on the road (hopefully soon)
my shops in new britain, off the corbin ave exit.
heres my list so far for oil and transmission fluid change. already have 0w40 mobil, i received a filter with my car its in a blue box says hamman 2609/1 oil filter.
looks identical to this, thoughts ?
http://www.ebay.com/itm/Mercedes-Benz-Engine-Oil-Filter-Fleece-OEM-Quality-Hamman-000-180-2609-/141046670664?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d7096548&vxp=mtr
Delete Part Number Availability Description Price Quantity SubTotal
000-180-26-09-M1014 100+ in stock
Ships Today!
Oil Filter Kit (Polyester Filter) Brand: Bosch Note: Recommended for Synthetic Oil and/or increased Service Intervals, Contains: (Qty.) (1) Filter Cartridge, (1) Filter Housing Seal, (4) Sealing Rings. (2006 Mercedes-Benz CLS55 AMG Base Sedan)
[More Info] [Choose alternate brand] $11.75
$11.75
05110-M633 100+ in stock
Ships Today!
CRC Mass Air Flow Sensor Cleaner, 11 Oz Can (2006 Mercedes-Benz CLS55 AMG Base Sedan)
- Hazardous Material: Must be shipped via ground shipping only, and is non-returnable.
- Item shipped via Ground shipping only.
[More Info] $9.25
$9.25
000000-000884-M22 67 in stock
Ships Today!
Transmission Drain Plug (10 mm Shaft Diameter) Brand: Genuine Mercedes Note: For Torque Converter and Transmission Oil Pan. (2006 Mercedes-Benz E55 AMG Base Sedan)
[More Info] $4.50
$9.00
C3743-INT Ships Today!
[why is this?] Cabin Air Filter (Charcoal Activated) Brand: Bosch (2006 Mercedes-Benz E55 AMG Base Sedan)
- This part may be shipped directly from the manufacturer.
[More Info] $11.75
$11.75
007603-014106-M131 100+ in stock
Ships Today!
Oil Drain Plug Seal (14 X 20 X 1.5 mm) Brand: Fischer & Plath (2006 Mercedes-Benz CLS55 AMG Base Sedan)
[More Info] $0.25
$1.00
111-997-03-30-M36 100+ in stock
Ships Today!
Engine Oil Drain Plug Brand: Febi Note: Also Use- (Qty.) (1) 007603-014106 Seal (2006 Mercedes-Benz CLS55 AMG Base Sedan)
[More Info] $1.75
$7.00
140-991-00-55-M22 100+ in stock
Ships Today!
Transmission Filler Cap Lock Pin Brand: Genuine Mercedes (2006 Mercedes-Benz CLS55 AMG Base Sedan)
[More Info] $2.75
$2.75
140-271-00-80-M30 100+ in stock
Ships Today!
Transmission Pan Gasket Brand: Elring Klinger (2006 Mercedes-Benz CLS55 AMG Base Sedan)
[More Info] [Choose alternate brand] $6.25
$6.25
007603-010112-M131 100+ in stock
Ships Today!
Transmission Drain Plug Seal (10 X 15 X 1 mm) Brand: Fischer & Plath (2006 Mercedes-Benz CLS55 AMG Base Sedan)
[More Info] $0.25
$1.00
Ships Today!
$11.75
Ships Today!
[More Info] $9.25
$9.25
Ships Today!
[More Info] $4.50
$9.00
[More Info] $11.75
$11.75
Ships Today!
[More Info] $0.25
$1.00
Ships Today!
[More Info] $1.75
$7.00
Ships Today!
[More Info] $2.75
$2.75
Ships Today!
$6.25
Ships Today!
[More Info] $0.25
$1.00
can anyone chime in on diff fluid? trying to wrap up my pelican parts order, need a few bucks more for free shipping. looking at Fuchs Sintopoid Ls 75W-140 or should i go with redline or royal purle 75w 90 considering the winters get kinda cold out here?
