Camber kit advise - kmac vs mbarts vs ??
I recently installed some massive 20 inch wheels (9"frnt and 11" back), and my car is lowered about an inch, and now I'm dealing with some massive negative camber issues. I've been reading and searching but I really can't decide on a definitive solution, I keep reading good things about KMAC bushing kit and also about MBARTS adjustable arms...
I would really appreciate some feedback from some users or people that have experience with either kit. Dollar for dollar it seems that KMAC it's a no-brainer but I would like some more info or experience on the Mbarts kit.
My car is running above 600hp and I am concerned the tires won't last long if I keep them the way they atm. I took the car to be aligned but it didn't do any good, car still looks like a flat footed kid
Appreciate any help
My ELM V2 lowers my car 25mm all around.
The rear tires look really bad, l have a hard time thinking that even if it is not lowered at all, I won't get massive negative camber...
I am looking at sorting rear camber issues on my E55. Mine has the Renntech V2 module fitted, I don't have it slammed it's currently at -20mm front and -15mm rear. The fronts seem to wear even after getting the geometry set but the rears are both out of spec, particularly one of them which for some reason has more camber than the other by about 1 degree! It currently has 18" AMG III's, 8.5" / 9.5" but I am fitting some genuine 19" BBS LM's 8.5" / 9.5" in the spring and I would like to sort it before then if possible.
Are there any other alternatives out there other than MBarts and KMac? I've read bad reports about both but thought the MBarts seemed the best approach
MBArts is a small company... I'd guess it's a 1-man shop and might even be a "part time" gig for the owner. Response times suck.... There is no arguing that. Here is something VERY important:
There are two methods to correct camber....push the TOP of the tire out, or pull the bottom of the tire IN. For our cars with wide fitment wheels/tires pushing the top of the tire OUT is probably a bad idea. There isn't much clearance at the fender (especially when lowered).... For that reason I'd avoid the MBArts solution. The K-MAC solution pulls the tire IN at the bottom, which is probably the smarter way to go on our cars...
Full disclosure: I've got a complete set of K-MAC bushings (newest design) that I'll be installing in the spring, and a set of MBArts rear toe links. The rear toe links seem OK so far, but I'm still not 100% happy with them. Unfortunately, the only other options for an aftermarket toe link are around $1300 (twice the price of the MBArts item) and seemed like a huge ripoff.
-G
I see you post a comment like this EVERY time that someone asks about MBArts. I have NEVER been able to find your original posts (with photos) that explained why you've got such a beef against this shop. If you want to speak as an "authority" on this subject, then provide some information about your experiences.... Otherwise you just sound like a clown with nothing valuable to add.
-G
My advice to you would be to get the new K-MAC's fitted now so I don't have to wait until spring for your thoughts
Sounds like a real hassle...... adjust/install wheel/check camber/remove wheel/adjust again... etc.-G
Does anyone know how much rear camber adjustment the K-MAC's allow?
-G
The early MBArt arms had some design flaws and a few people had serious failures. Since the beginning the arms have undergone at least 3 updates and I believe the newest generation are up to the task. I received replacements sets for each update and have never had anything but great customer service and quick responses from MBArts. However, my last contact with them was easier this year so I can't speak to anything recent
My current rear wheels are AMG's 18x9.5" ET33 and my BBS LM's are 19x9.5" ET32 so almost identical offsets (in theory the LM's will project 1mm further out). The LM's are new to me so have never been fitted on my car but with the offsets are so close they should fit OK, they are also the correct wheel (LM155) as listed on the BBS website.
Good news... The SPC rear camber bushings for 211chassis has just been released this past friday. I.spoke with SPC earlier this year, although they have no plans for fronts, these rears are adjustable with the wheels off.
Import Auto Performance has a package deal for both rear sets and the mandatory installation bushings for only $199 free shipping. 800-672-0066, ext. 501, ask for Peter. I just ordered mine, and just to be sure I will measure my bushings this afternoon per the installation Instructions. FWIW I have no affiliation with any of these companies, just excited to finally have a reasonably priced option for our cars, plus I just put new tires on the rear and can already see the inside tread taking a beating.
Btw, it looks like Import Auto Performance has these on Ebay with free shipping for $149!
