285/30/18
1999 MB C43 2004 E55 AMG, 2004 Suzuki GSXR, gl63
285/30/18
I found a good deal in 285/30/18. Will these tires look bulkier then the stock 265/35/18's? I like the low profile look so I don't want too much side wall. Would the 275/30/18 be a better option on the stock rim in that case? Or are the benefits of the larger food print negligible and should I just keep with the stock size?
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
http://www.1010tires.com/Tools/Tire-...5R18/285-30R18
Stock Tire Size
265/35R18
Imperial
Section Width:
10.43 in
Rim Diameter:
18 in
Rim Width Range:
9 - 10.5 in
Overall Diameter:
25.30 in
Sidewall Height:
3.65 in
Radius:
12.65 in
Circumference:
79.49 in
Revs per Mile:
822.03/mi
Actual Speed:
62.14 mph
Speed Variance:
Diameter Variance:
Tire Size 1
285/30R18
Imperial
Section Width:
11.22 in
Rim Diameter:
18 in
Rim Width Range:
10 - 11 in
Overall Diameter:
24.73 in
Sidewall Height:
3.37 in
Radius:
12.37 in
Circumference:
77.70 in
Revs per Mile:
841.01/mi
Actual Speed:
60.74 mph
Speed Variance:
2.31% too slow.
Diameter Variance:
I am running 295/35/18 right not on stock rims with no problem though they are a little more ballonish but hook way better
+1 ^ 265 way to small for are cars in modified form (unless they are drag radials)
275s not much wider
even 285 is less than 1 inch wider than stock (0.8 inch)
i believe a few people have run 305 in the back on wider rim... im running 295 with no problems on stock rim and the tire tech said it fit fine with a little room to spare
275s not much wider
Do you guys have shots of your car's rears?
I'd like to see how 285s/295s look on an otherwise stock car. 285 would be a nice jump, 295 would be awesome on a stock wheel, pics would be great.
gaspm - no rubbing at all with 295s on stock rims? Your entire suspension/height is stock?
I am going to need tires likely by the Spring/Summer. Thanks.
