Looped Fuel Rail Install Problem
Old 12-24-2013, 12:21 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by cij911
Shardul - Were the cars that failed logging AFRs on the #8 bank ? I have seen quite a few modified cars without proper logging setups and it just baffles me. That said, even with my setup, I am still concerned about the fuel delivery (I would prefer larger pumps, line, and a return)...
IMO, logging AFR's isn't going to give you enough info to always prevent catastrophe. EGT's are the only way to see what's really happening and even then I don't think individual EGT's can even be checked on a stock motor due to the log style exhaust manifold. It would take a lot of effort to watch #8 by itself.
Old 12-24-2013, 12:26 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Wow .. drama! I went an extra step and moved the feed to the centre of the rail at the back of the engine. Can't prove that it will help. It just seemed suspicious that the feed comes in at an angle on one side.
Old 12-24-2013, 12:44 PM
chiromikey's Avatar
I went that route also...
Old 12-24-2013, 01:44 PM
turbo97se's Avatar
You're right on the money here … AFRs are too slow. EGTs much faster. Could consider putting in EGT probe right at number runner 8 if that is the weak one.
Like your rail style .. better than mine, mine Tees in without the sloping.
Old 12-24-2013, 01:48 PM
Joncl's Avatar
E55
egt probe on each bank would be great but this thread was about a stock car blowing not a modded car that is why I asked about the link to threads about stock cars popping
Old 12-24-2013, 01:52 PM
turbo97se's Avatar
Really? I thought it was about looped fuel rail install problem like the title states
Originally Posted by Joncl
… this thread was about a stock car blowing not a modded car that is why I asked about the link to threads about stock cars popping
Old 12-24-2013, 02:00 PM
  #32
Joncl's Avatar
E55
Ya from looped fuel rail it went to stock engines popping
Old 12-24-2013, 02:22 PM
  #33
chiromikey's Avatar
Yeah, it got side tracked but I'm still kinda interested in reading about these "stock motors that have been popping #8 for years now".
Old 12-24-2013, 02:40 PM
  #34
Joncl's Avatar
E55
Me too
Old 12-25-2013, 01:15 AM
  #35
e55amgrocket's Avatar
Dirt Scooters
#8 isn't just a fuel issue. It's compounded by being the hottest cylinder to begin with (furthest from water pump) and if anyone has checked temps with a heat gun they would see it's always warmer than the other cylinders. The rail inlet being right there doesn't help either obviously.
Old 12-27-2013, 09:10 PM
  #36
EREBUS's Avatar
clk63, cls55, ml63, (w210) E55
Got a little busy with the holidays......I'll find some links, mikey. Just hold on to your little ponies. lol
Old 12-28-2013, 10:09 AM
  #37
chawkins2001's Avatar
2006 E55 AMG
Did you get the rail from BI-Performance (me) ?
Old 12-28-2013, 12:09 PM
  #38
EREBUS's Avatar
I bought mine from a member here that goes by roverron. Brand new and never installed.
Old 12-29-2013, 02:25 PM
  #39
chiromikey's Avatar
Lol...of course you will...
Old 12-29-2013, 02:27 PM
  #40
Joncl's Avatar
E55
lol
Old 12-30-2013, 01:29 AM
  #41
EREBUS's Avatar
the air pump reflash even left some unmodified cars running lean and i have my suspisions about this one. if i had let mine go without luckily finding a service manager that actually knew our cars, i'd likely have run into the same problem being discussed here.
^^^^^kinda ironic, don't you think mikey? you posted this 5 years ago on how a stock motor can lean causing an engine problem. was this #8? and yet, you keep talking your sh*t....
https://mbworld.org/forums/w211-amg/...gine-help.html
http://www.benzworld.org/forums/gene...placement.html
http://www.benzworld.org/forums/w221...oke-oil-2.html
http://www.benzworld.org/forums/w210...ed-piston.html
http://www.pistonheads.com/gassing/t...nions%3F&mid=0
Does everyone with a #8 piston failure post on the internet? No. Cylinder #8 on the M113 and M113K is the leanest and hottest. If the engine was to lean or overheat, #8 is the most common to fail. This is what the techs at MB are telling me. Why do simple mods to our engines cause #8 to fail first, also?
My point is that #8 cylinder is the most sensitive to fuel starvation.......even on stock motors. Sorry if you don't agree?
Old 12-30-2013, 01:31 AM
  #42
EREBUS's Avatar
lol
spit it out and get off your knees. you are embarrassing yourself, boy.
Old 12-30-2013, 07:47 AM
  #43
Joncl's Avatar
E55
first ,even to think something like that makes you a ******* of the highest caliber so stop and get to the matter at hand. second , those links actually show only 2 55k engines popping and with one he's a second owner and doesn't know if it was ever modded so damage could have already been done, the last guy also was a 3rd owner but seems like it was always stock so maybe you have 1 guy that popped on a stock 55k motor
Old 12-30-2013, 11:35 AM
  #44
simon1966's Avatar
E55 AMG WAGON 2004
I like the look of this principle, is anyone modding these on a commercial basis? Would this be even better if looped or is it not necessary?
Old 12-30-2013, 02:06 PM
  #45
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Does everyone with a #8 piston failure post on the internet? No. Cylinder #8 on the M113 and M113K is the leanest and hottest. If the engine was to lean or overheat, #8 is the most common to fail. This is what the techs at MB are telling me. Why do simple mods to our engines cause #8 to fail first, also? [/B]
FULLY AGREEEEEEED, WITHOUT DOUBTING.....
ZAYED,,
Old 12-30-2013, 02:27 PM
  #46
chiromikey's Avatar
Thanks for wasting my time...but at least you proved yourself wrong so I didn't have to. Your exact words were "#8 has been popping on stock motors for years" and you came up with a post of mine discussing a possible lean condition having nothing to do with #8 or popped motors.
Nobody ever argued that 8 isn't the weak link, just that it doesn't come into play often on stock motors like you falsely claimed...
Old 12-30-2013, 02:29 PM
  #47
chiromikey's Avatar
Floored Fab did a few but is only taking select customers now. It wouldn't be difficult for someone to do this if they have the right tools/ability. I didn't loop it since it already takes care of the low pressure situation at #8 on motors that need more fuel than stock.
Old 12-30-2013, 02:55 PM
  #48
simon1966's Avatar
E55 AMG WAGON 2004
Thanks for the info. I'm in the UK so don't think I would count as a 'select customer'!
My car isn't currently heavily modded, pretty much EC stage 1 with s/c pulley, map, HE, Bosch 10 pump, LFR7AIX cooler plugs, bmc filters. Also has x-pipe, resonator delete and quaife LSD. Power isn't massive at 550bhp at the wheels and 618lb/ft on the dyno. I am looking into the next steps which will most likely start with headers then split cooling.
I was thinking a looped or modded fuel rail would be a good idea before I do anything else - any thoughts guys or is it not necessary in my current state of tune.
Old 12-30-2013, 03:10 PM
  #49
chiromikey's Avatar
I was thinking a looped or modded fuel rail would be a good idea befor e I do anything else - any thoughts guys or is it not necessary in my current state of tune.
I think you're right to consider a rail as your next mod but I'd also consider upgraded oem blue injectors or the 550cc injectors if your crank pulley is larger than 180mm (or whatever the s/c pulley equivalent is).
Old 12-30-2013, 03:13 PM
  #50
cm60k's Avatar
Looped rail is an Excellent option for cylinder #8 starvation during hard WOT situation,
MB done that in their brilliant SLR Engine with special injectors & as remember 5.0bar regulator.....
ZAYED,,
Quick Reply: Looped Fuel Rail Install Problem
