Retrofit DIY: 07-09 to pre facelift 02-06 Headlights lot's of pics
Old Oct 31, 2017 | 11:31 AM
MACEDON's Avatar
05 E55, 98 CLK320
So 2 posts above I posted pictures, and you'll find that my old light is halogen, but what you don't see is that it's converted to HID with a ballast kit.
However, remove the kit and it's all back to stock.
The new lights are exactly these:
https://www.ebay.com/itm/2003-2009-M...9X9Z9m&vxp=mtr
But I think I'm going to have to sell them because I am ordering ones from Gary Lo that will be plug, play, facelift, and converted all in one- apparently.
Old Oct 31, 2017 | 01:49 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
The Ebay item you purchased is not as described so you may be able to file a dispute. Looking at the connectors, the Ebay lights you bought are for 07-09 and not 03-06 as is claimed in the Ebay description. It's worth a shot at least.
It's a bit of a pain to convert but it's doable. I have done this a couple of times now and gone from Xenon back to Halogen without issues, but some coding is required.
Old Jan 4, 2018 | 10:32 PM
stanlychou's Avatar
W211 E280
Originally Posted by turbo97se
I recently completed facelift headlight update by fitting my current 02-06 headlights with the inserts from 07-09.
Hi turbo97se,
Happy 2018 ~~
Thanks for the sharing, recently my 2005 pre-facelift E350's headlight with Bi-xenon and AFS were broken, after read your post, I decide to do the same retrofit with you, but I got some questions:
1) How about can bus connector? did you connect the two CAN BUS wire between headlight and vehicle?
2) If you do so, is that work perfect? the new headlight can be recognized by DAS/Xentry system ?
3) How did you calibration the new headlight ?
Thanks again.
Old Jan 9, 2018 | 08:22 AM
MACEDON's Avatar
05 E55, 98 CLK320
I just ended up getting lights from Gary Lo at Suvneer... they were plug and play, returned the ones that needed retrofitting. Much better deal
Old Jun 19, 2019 | 02:57 PM
George Noneja's Avatar
e55 amg w211
Canbus Connectors
Where did you find all of your connectors? More so the CANBUS than the others.
Old Sep 16, 2019 | 05:42 AM
Nerijus's Avatar
w202t c280 145kw sport/avangard w211 e220 cdi
Hi maybe someone can help with 07-09 to pre facelift 02-06 headlights? Both is bixenon just need to know how to connect it
Old Oct 3, 2019 | 10:45 PM
  #32
Bouncer-01's Avatar
2010 Mercedes C Class C200 2143cc diesel
hi mate, I'm trying to upgrade my 2010 w204 halogen headlights 10 pin to 2011 w204 facelift xenon headlights 14 pin, getting confused with wire colors! any chance that you could help :-)
I wanna cut the wires of 10 pin adaptor and join them to 14 pin cables? I'll be appreciated if you can help. Regards, Stephen.
Old Dec 21, 2019 | 02:52 AM
  #33
turbo97se's Avatar
Re-uploaded all the images since they were all broken. Fortunately, I still had the pictures. If someone could make a PDF and link it that'd be great. For some reason, I cannot.
Old Dec 21, 2019 | 04:48 AM
  #34
MSG 55G's Avatar
Veteran: Army
2006 E55
I cheated and just changed the facelift chrome liner on my stock Bi Xenon.
Old Jan 8, 2020 | 11:14 PM
  #35
TotoRiina's Avatar
e320 cdi
Hey so i own a E320 CDI 2006 and i did the retrofit for the headlights, do you have any idea why my bi xenon doesnt work ? everything else works perfect. other than the highbeam bi xenon future and i think the cornering one as well
Old Apr 1, 2023 | 06:50 PM
  #36
ethan214's Avatar
2006 Mercedes e500 4MATIC, 2002 E320 4MATIC Wagon
Canbus?
Hello, does anyone know where to tap into canbus? I have everything else wired up but I don’t know where to wire the canbus wires to. I’m not familiar with canbus and I know it says CAN-C but I can’t figure out where that is. Thank you!
Old May 12, 2024 | 12:30 PM
  #37
SuperTier's Avatar
W211 E500 4Matic Kleemann 500-K2
That's what I don't get. How has this entire thread gone by without any information on the most crucial part of this retrofit.
I know the central gateway for CanBUS is located under the steering wheel column, but how exactly does one setup the wiring to pins S2-4 S2-5 from there?
I feel like I'm missing something obvious.
Old May 12, 2024 | 12:41 PM
  #38
bobgodd's Avatar
2004 E55
There are several canbus points in the car, my guess would be you'd have to use what's already in use so the correct control module can do it's job. There's another connection point under the dash on passenger side near the center console, one in the drivers side where the cabling runs along the door, and one in the trunk on the driver's side near all the electronics. Since it's a bus, you don't need discrete wiring points necessarily, just need to get the signals to the bus. I can't remember the coloring but if you use a DMM to probe voltage it'll be obvious which is CAN+ and CAN-.
Old May 12, 2024 | 04:36 PM
  #39
SuperTier's Avatar
Appreciate the reply, still just as lost though. OP listed 2x CanBUS connectors 0375455928 as necessary, how would I wire them into one of the interior CanBUS hubs all the way from the headlights. Especially with the short connectors he listed. I really can't wrap my head around this.
