Weird 55 DAS question
Old Dec 30, 2013 | 10:42 AM
sk8erjosh09's Avatar
M113 E50 6-speed, 2005 E55 AMG
Anyone know how to access a 55K ECU without a CGW present in their vehicle? I understand if you own a 55 you wouldn't need to deal with this problem, but figured I would post here anyway just in case.
Old Dec 30, 2013 | 10:43 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you may have to manually select the vehicle to get to the control units.
Old Dec 30, 2013 | 10:46 AM
That's what I tried first, then tried with the VIN coded in the Immo. As soon as I select ME SFI it says it cannot connect to unit and if you click ok and try again it says, cannot connect to CGW.
Old Dec 30, 2013 | 11:05 AM
shardul's Avatar
yeah then you may be out of luck. you will need a new CGW they are relatively cheap.
Old Dec 30, 2013 | 11:15 AM
My car never came with one, I wonder how fitting one in would go.
Old Dec 30, 2013 | 11:17 AM
shardul's Avatar
it is a small box with one connector for a harness. All you would have to do is find the harness and plug in the CGW. it is located under the dash by the hood release.
Old Dec 30, 2013 | 11:33 AM
Do you think I have a connector for it already there? I have an R170.
Old Dec 30, 2013 | 12:08 PM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
What is a CGW???
Old Dec 30, 2013 | 12:11 PM
Originally Posted by Crissus
What is a CGW???
Central Gateway. It's a long shot trying to rig one into place but I need a solution to get into this ME unit in DAS Developer. Pre-coding my modules to this ECU didn't work. The ECU is worthless without the CGW or a bypass of some sort.
Old Dec 30, 2013 | 12:13 PM
The higher end MB models came with it as another communication module. The lower end SLK's, C's etc. don't have them. Hell the R170 doesn't even have a SAM.
shardul's Avatar
yes it has it
Old Dec 30, 2013 | 12:15 PM
Wow, well I'll go looking for it and see what I find. For coding a CGW, do I need a new one or can I buy used? I saw one for $50 which is why I'm asking.
Old Dec 30, 2013 | 12:16 PM
shardul's Avatar
considering the issue you are having with connecting i would get a new one.
Old Dec 30, 2013 | 12:33 PM
Well thanks Shardul, I'll go looking for the plug in a few and report back.
Do you think that there will be issues since I don't have a SAM, DAS module or most of the other modules you guys have? I have an RCM, SKREEM, and run the old style transponder key. I'm guessing I could set all of it to not present in the cgw coding but want to make sure.
Edit: I meant I don't have a DAS Module not EIS.
Old Dec 31, 2013 | 10:32 AM
No plug found under the dash, but I think I figured it out.
Thanks again for the help Shardul,
Josh
Old Dec 31, 2013 | 10:45 AM
shardul's Avatar
no problem keep us posted.
Old Dec 31, 2013 | 01:07 PM
E55Greasemonkey's Avatar
This place is a joke.
If your 170 has it...did you try the 38 pin underhood connector? Or, the obd2 under dash?
Old Dec 31, 2013 | 01:30 PM
My R170 is the newer without the 38 pin, I only have the 16.
Old Dec 31, 2013 | 01:52 PM
Ok, did you try telling star you were working on a 55 and manually accessing the ecu? Aka control units/drive/me
Old Dec 31, 2013 | 01:54 PM
Alright, was worth a try.
Hey I appreciate it. Any ideas and help is welcome. I think we got it though, will know for sure tonight.
