We need alcohol sensor and E85 mapping!
Below is a 2014 cyc air flow map for flex fuel for the new GM direct injection v8. I been doing some E85 testing on this engine and saw the aggressive timing maps built in by GM for 2014.These maps did not exsist on thier 2013 models but is a nice bonus for the new engines. Notice the 6 deg advance with E85 at 4800 rpm! I tested mixed ratios of e85 and 93 octane and the onboard alcohol sensor would add less timing, once it saw lower alcohol content. In short, this is like having a built in RACE tune! The GM motor can run on 87 or 93 and make its rated HP but once you add 100% E85, power jumps 20-30 hp and 40-45 TQ (N/A engine) by just using the yellow gas hose at the pump!
Below is a new sensor coming out that can help us in running E85 more effectively and be able to just add E85 and let the sensor adjust your tune to full Race! There are some other sensors out already but wanted to share the new one from haltech as well.
http://www.haltech.com/flex-fuel-sensor/
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
http://www.proefi.com/
