Winter Wonderland my ass
I just spent 30 mins digging my car out, too. To make matters worse, there was a layer of ice (from the freezing rain) at the bottom so I had to brush the snow off first and THEN scrape off all the ice.
I've officially had it with winter. This year has been the most brutal in almost 10 years, and we're only starting off January. WTF!
2004 E55 AMG; 1991 Previa
Antifreeze serves its purpose by literal definition. Antifreeze is less effective than water in thermal transfer, it's only used to lubricate and prevent the water from freezing
Car's have a sealed recirculating cooling system which when properly maintained with antifreeze, prevents the coolant from freezing, even in extreme temperatures.
Btw what color? Looks like Tektite???
That's because boats pull their cooling water directly from the water they float in, which has not been treated with antifreeze. So when the temps drop the plain water which has been pumped into the engine freezes, and can crack the block.
Probable cause for boat motors freezing would be the presence of water not removed totally from the block. "Frost" plugs are just ports to remove moulding sand from the block. To rely on the frost plugs being pushed out from a frozen block would be a wager you would not win often. Ice knows no direction and will push the block out wherever, most times in the valve lifter gallery where the walls are thin. For all you guys running water only in your cars and are now subject to freezing temps, either garage the car in a heated garage or get some anti freeze into the rad now. Windshield washer bottles are often ignored and have water in them, they freeze quite nicely also and usually take out the washer pump when frozen. Bigking we had -28C, no freeze issues.
Wow! Maybe a quality tarp would help but I know very little about snow , being from Texas
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Yes, understood (although we would still need to calculate the freezing temp with mixed antifreeze). My question is why is it so common for boats to have cracked blocks in the winter time and not our cars. Is it user error (starting when its frozen) or does it really get that cold that they just pop the block plugs? Let's not just keep the discussion to antifreeze, theres 4-5 other types of fluids in our cars that could potentially freeze and cause damage. but I have family in St Paul MN and its -17 over there so just a thought.
The driveway and walkways suck, I'll let the sun melt all this away
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
I feel your pain. This was my S600 a few years back when we had record snow in Chicago. It was parked outside while I put the 55 engine in the c43. I think we had around 18" of snow overnight.
Its currently -15 out.
This is the worst we've had in years actually. I'm more bummed that the car isn't in the garage getting worked on than I am about the snow :shrug:
