FUEL FILTER CHANGE
Old Jan 9, 2014 | 11:42 AM
BI-Performance's Avatar
Former Vendor of MBWorld
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
Yes sir, one in each basket on the US passenger side. We did not touch the sender unit on the US driver side with this project, although I am working on eliminating that sender unit/fuel filter crappy setup.
Old Jan 10, 2014 | 11:44 AM
scoto's Avatar
2005 E55, 2007 ML63, 2008 SLK, 2015 GLK350, BMW Z3, Dodge Power Wagon, Electric Smart car
Craig & Forrest,
What filters did you use with your AEM fuel pumps? Where did you locate them? Any photos of install?
Old Jan 10, 2014 | 12:06 PM
Forrest Gump 9's Avatar
shrimp boat
Originally Posted by WANTED!!
Whose pumps did you use and do you have any pics of the modification? I was thinking about doing something like this anyway.
Originally Posted by scoto
Craig & Forrest,
I used the black AEM fuel pumps because I still run pump gas. The AEM comes with:
-electrical plug-to splice into the stock harness
-filter
-hose and clamps
To make this work for me I have to dremel out the bottom of the baskets, removed the filters and slid the stock pumps out.
On the AEM units:
-put the hose on the fuel outlet and put a clamp on the hose tight
-intall the filter on the pump
-slide the pump and filter assembly thru the opening on the bottom of the basket that you've dremel out earlier
-connect the fuel hose and clamp it tight
-connect the electrical lines
And you should be set.
Old Jan 10, 2014 | 12:23 PM
Joncl's Avatar
E55
Forrest, if there's only one pump on the stock setup why did you use 2 aem pumps?
Or is there 2 pumps in the stock setup?
I thought the other side is a sender
Old Jan 10, 2014 | 12:41 PM
shrimp boat
The 03-06 E55 use two pumps and a sender.
Old Feb 21, 2022 | 12:15 PM
Endri55k's Avatar
Cls55
Originally Posted by Forrest Gump 9
The fuel filters are built into the fuel pumps. The fuel pumps assembly cost about $500 from the dealer.
As far as the special tool goes, a hammer and a big flat head screw driver work great. I've taken my fuel pump in and out many times I can R&R one in 30 min. It's not that hard, just don't forget any hoses.
can you show me how to open the fuel filter cap,iam trying rotate clockwise but notthing,thnx
Old Feb 21, 2022 | 08:55 PM
  #32
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Locked position on right mark, unlocked position on left mark. Vise with padding and a strap wrench. Takes quite a bit of effort to separate. Use lubricant to reassemble (KY jelly or similar). BTW, you resurrected a thread that is eight years old.
Old Feb 22, 2022 | 10:36 AM
  #33
tlambert's Avatar
2005 E55 AMG
Here is the fuel filter for the 03-06 E55 from Creative Steel.
https://creative-steel.com/shop/merc...t-fuel-filter/
Old Oct 2, 2022 | 07:59 PM
  #34
bobgodd's Avatar
2004 E55
Thanks for the pictures, definitely helped. One thing I'll add, once I depressed that little locking tab, mine was extremely easy to open. It turned like it was its job. I didn't have to disconnect anything or take the sending unit out of the car. For anyone trying this, I'd suggest trying it in situ first.
