FUEL FILTER CHANGE
Old Jan 6, 2014 | 05:13 PM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
FUEL FILTER CHANGE
Gents,
Can anyone direct me to a previous thread or there personal experience on changing out the fuel filter/s?
1. What mileage should it be done at?
2. Can I do it myself?
3. Cost at dealer?
Currently at 70k miles!
Old Jan 6, 2014 | 05:18 PM
E55Greasemonkey's Avatar
This place is a joke.
MB spec is 60k miles.
Doing it yourself, depends on your mechanical abilities. You also need a special tool to take on/off the lock rings to the senders.
Dealer charges about $800.00
Old Jan 6, 2014 | 06:14 PM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
Originally Posted by E55Greasemonkey
MB spec is 50k miles.
$800? I guess its true it resides right on top or by the tank right? See what my indy charges. Thanks bro...
Old Jan 6, 2014 | 06:52 PM
Forrest Gump 9's Avatar
shrimp boat
The fuel filters are built into the fuel pumps. The fuel pumps assembly cost about $500 from the dealer.
As far as the special tool goes, a hammer and a big flat head screw driver work great. I've taken my fuel pump in and out many times I can R&R one in 30 min. It's not that hard, just don't forget any hoses.
Old Jan 6, 2014 | 06:57 PM
Toadster's Avatar
2005 E55 AMG
both fuel senders replaced at my dealer was $2,400
Old Jan 6, 2014 | 07:07 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
That's the wholesale price of both sending units only.
Old Jan 6, 2014 | 07:44 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
You are only changing the one with the fuel filter in it. No need to replace the fuel pumps.
Old Jan 6, 2014 | 07:49 PM
Here we go again. The fuel filter trolls have arrived.
Old Jan 6, 2014 | 08:51 PM
AMG E Power's Avatar
E55 amg
My owners manual says 60,000 miles is when fuel filter should be changed.
I think parts . Com has them for 350 each.
Old Jan 6, 2014 | 09:46 PM
I stand corrected. It's 5yrs/60K
Old Jan 6, 2014 | 10:19 PM
MAN55LE's Avatar
04 E55 AMG
https://mbworld.org/forums/w211-amg/...smell-fix.html
Old Jan 6, 2014 | 10:20 PM
MAN55LE's Avatar
04 E55 AMG
https://mbworld.org/forums/w211-amg/...ation-diy.html
Old Jan 6, 2014 | 10:23 PM
MAN55LE's Avatar
04 E55 AMG
https://mbworld.org/forums/w211-amg/...el-filter.html good links
Old Jan 7, 2014 | 07:33 AM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
had mine replaced last summer , equiv of $800-900 for parts, got my local mb garage to fit for $100.
both pumps have filters so both should be changed at the same time.
no point changing is they are working fine though
Old Jan 7, 2014 | 09:33 AM
cij911's Avatar
one car at a time
Sorry, but I am a tad confused...The kits (pump, new housing, and new filter) seem to include just one side (driver side) , what about the passenger side ??
Old Jan 7, 2014 | 09:41 AM
novae500's Avatar
W211
Back in november, my car stalled while driving. Thought it was the CPS, nope, but ended up being the fuel pump (passenger side) not working and the driver side fuel filter was leaking which was replaced 16,000 miles prior at dealership. Ended up replacing both sides for about $945 for both and additional parts $40. Labor was $370 including diagnosis fee.
Old Jan 7, 2014 | 09:51 AM
cij911's Avatar
one car at a time
Thanks ! I thought folks should be replacing both sides, unfortunately it appears the kits linked in the Maintenance thread, which is very helpful (made by Toadster), only shows the driver side.
Greasemonkey - Since you actually have done these a few times , should folks be replacing both sides every 60K miles ?
Everyone else - where do we find the passenger side kit ? Looks like the combined parts (both sides) should be ~ $700 - 1000.
Old Jan 7, 2014 | 10:00 AM
novae500's Avatar
W211
i got mine on ecstuning. Came from MB dealer package. i didnt want to chance getting stranded again. Wasnt fun with $200 tow bill after waiting 2 hrs, over 60 miles from my house.
Old Jan 7, 2014 | 12:06 PM
shrimp boat
Just like anything MB, everything is over built.
The fuel pump is on the US passenger side. There are actually two pumps in two baskets. Each pump has it's own filter.
The sending unit is on the US driver side. It receive the gasoline from the pumps and send it to the engine. The sending unit also has its own filter.
The fuel pumps do go bad. The sign of that are:
-the melted electrical plug
-filters are blacken (should be white/yellowish)
If you're handy and cheap like me, you can replace the pumps and filters by using the aftermarket pumps. Thanks to chawskin I was able to retrofit two 320lph pumps in place of the stockers. This will involve some hacking of the stock baskets and ghetto rig the hoses. It's been working fine on my car for about 1k miles. Cost about $250 so I'm not sure if it worth it.
As far as the sending unit goes there is no way to tell if it's bad or not. The filter is built internally and if you open it up to check, there's no way to put it back (may be there's a way but I have not been able to). The plastic on the sending unit is very brittle. There're some reports of cracking. If you decide to work on the sending unit pay extra attention to the nipple, it's very fragile.
Hope this will help clarify things. Also, if your car still have the black sending/fuel pump seals, change them. The newest version is green.
Old Jan 7, 2014 | 12:08 PM
Toadster's Avatar
2005 E55 AMG
since having my pumps replaced, there's a much more pronounced 'humm' from the pumps...
it's somewhat annoying
Old Jan 7, 2014 | 08:11 PM
Shifter's Avatar
E55, SL63, ML550
[QUOTE=Toadster;5898634]since having my pumps replaced, there's a much more pronounced 'humm' from the pumps...
Mine did that also after replacing them toad! Then even worse, the car under any load would cut out, loose all power. Wideband showed it going off the scale lean. Connected a fuel pressure gauge and saw pressure drop as soon it goes underload. Ended up replacing them again (parts warranty)and the second set is all good.
Old Jan 7, 2014 | 10:55 PM
Toadster's Avatar
2005 E55 AMG
[QUOTE=Shifter;5899261]
ouch - that sucks!
any way to test it on the car?
Old Jan 8, 2014 | 05:46 AM
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
Whose pumps did you use and do you have any pics of the modification? I was thinking about doing something like this anyway.
Old Jan 9, 2014 | 08:08 AM
BI-Performance's Avatar
Former Vendor of MBWorld
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
We used these pumps brotha, the E85 versions but the black is ok for regular pump:
http://www.aemelectronics.com/high-f...uel-pumps-101/
Old Jan 9, 2014 | 10:31 AM
Joncl's Avatar
E55
Craig do you have to put one on each side?
