HELP Checked my rear battery 13.1V is that bad
For trying to be frugal, you sure have poor deductive diagnostic reasoning.
Did you load test the batteries, or how about an alternator output check, just because the brushes are a certain length does not mean the unit is right. Possible shorting of the alternator when your seller removed it or if the car was involved in a crash then possible to short out the charging system at that time. Used is not always the best value when buying electrical items. They all look good, but the operation can be sketchy, as you have found.
To repeat myself, have never in my life seen any 12V battery in normal usage give 13V readings.
Again sorry about the finger, fingers have many nerves in them and the pain is indescribable, try holding it up should reduce the pounding.
