Injectors
Old Jan 8, 2014 | 10:28 PM
Redw20855amg's Avatar
Blown 208 55 amg, 211 55 amg
Injectors
Will any of these finds work on our mercedes I'd Like to find a couple sets for around 300. I need a set for my supercharged W208 also to finally finish it lol
http://www.ebay.com/itm/8-Authentic-Bosch-EV14-52lb-550cc-injectors-60mm-Rsx-Evo-Ford-Chevy-etc-/261365109043?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cda931133&vxp=mtr
http://www.ebay.com/itm/Ford-Infiniti-Nissan-Porsche-BMW-Mercedes-550-cc-Fuel-Injectors-AUSE-Series-/251149422431?pt=Race_Car_Parts&hash=item3a79ac0f5f&vxp=mtr
Old Jan 9, 2014 | 10:15 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Best way to tell, is measure lenght , o ring size and then buy the correct harness adaptor.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jan 9, 2014 | 06:06 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
If you are running a standalone ECU, Ebay injectors can be considered - and follow what Exotic-metal55 said. If not, work with your tuner on injectors. There are other factors besides just pulse width that need to be considered. The injector opening time and closing time (primarily opening - not the pulse width itself) can affect drivability especially at shifts and throttle tip-in. If you are working with a tuner they will need adjust for these factors and it can be a headache if not on standalone.
I ran into these issues on one of my cars but fortunately could compensate on my Standalone.
