Washer Fluid Not working
Old Jan 10, 2014 | 01:31 PM
1cerberus4u's Avatar
2007 E63
does your washer fluid dispenser make sound when you push the lever for fluid?
Reservoir is full and yet nothing comes out when I push the stick, and I hear now sound.....
Could be the system is frozen as the car came up here from Tx last week and I have no idea if you southern people just put water in the Reservoir or fluid
Old Jan 10, 2014 | 02:33 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
The lines or nozzles could be clogged. Open the hood and see if you can disconnect the hood nozzles from the feed line(s). Then use gentle compressed air to blow them out.
Old Jan 10, 2014 | 04:10 PM
06cls55amg's Avatar
06cls
press harder on the switch., i thought mine was broken as well, ended up being that i wasnt pushing it in far enough. it will feel like a you are pressing against a spring and stop, press in another 1/8 inch.
Old Jan 10, 2014 | 04:34 PM
black06c230's Avatar
mgLipGD
Mines broke but again its filled with meth!!!
Easy to access just jack up the car and remove the fender liner and you can get to the whole bottle. Don't even have to take the wheel off if you simply just want to check it out.
Old Jan 10, 2014 | 07:32 PM
2007 E63
As 06CLS said, I just needed to push harder on it and it worked, but not every time, so i'm half way there!
