Command powers dashboard and ignition?
I'm installing the ******* http://*****************/ in my car for external video input in the factory stereo, I remove the CD changer and command, and everything came out pretty easily, no broken connectors, however the car is now "dead", no lights on the dashboard and you can't start the car with the key. Does the ignition and dashboard share power with the command system and required to start the car ? I did a bit of searching and didn't find any hits, so started to wonder if I blew a main fuse or relay while doing the removal by accident.
I'm about to put the system back in this weekend with the ******* installed, but wanted to check if I had more work ahead.
Also, my car has the external audio input in the glove box, but it doesn't work (switching to aux has no noise at all, not even static), I checked the connections at the back of the stereo and it looks pretty firmly plugged in, would it be advisable to just buy a new external input cable assuming the one I have has a break somewhere between the radio and the glove box ?
Thanks!
fuses... check the dash side panels.
******* had bad experience with, I use only navtv. good luck
why didnt you just get an opti 1 with a real radio?
wasn't familiar with the OPT1, may take a look, I do hate the factory setup but all the replacements (android based) got bad reviews and there didn't seem to be a decent integration with a high quality head unit. I'll do some research on the opt1.
Where did you get the opt1 ?
I just tested it and am reading 2v across the terminals, charging for 2 hours hasn't made a difference, I guess its toast.
