Smaller Upper Pulley 84mm bearing bad need part#
Old Jan 19, 2014 | 04:25 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Just about 2500 miles on it and bearing is making noise,thought it was my tensioner bearing so changed that and still noise ,so with it idling I CAREFULLY slowed down supercharger to a stop as it has some slight parasitic drag and noise got louder , also with this low mileage it shouldn't be making noise already has anybody else had to change out this bearing on this pulley ? And need part number thanks
Old Jan 19, 2014 | 04:37 PM
Smalone01's Avatar
E55 Wagon, E550 Conv
Yeah, I had to replace mine also.
Nachi. 45BG07S5A2G-2DL
Found it on eBay for $55.00
Old Jan 19, 2014 | 05:34 PM
Toadster's Avatar
2005 E55 AMG
wow 2500 miles is pretty low for the bearing to fail...
link to my replacement - so far so good! https://mbworld.org/forums/w211-amg/...oing-well.html
it's holding up well
Old Jan 19, 2014 | 08:50 PM
cnterline's Avatar
Ok thanks I found a real Nachi bearing and it's on the way
Old Jan 20, 2014 | 01:04 AM
rios's Avatar
E55 AMG
If you struggled on the install and the pulley didn't go on smoothly and you banged on it you may have damaged casing for sealed bearings. I had a tough time trying to install a cold pulley on a hot car even hours after I thought it had time to cool. The old pulley slipped right off but then, they were at the same temp. I resorted to put ice on the supercharger shaft until the pulley slid right on and all the way back like butter.. Could have waited overnight but I started the job at work on my breaks and had to finish it...
