i changed my oil and sensor giving weird readings.
I specifically told you guys the increments already at 169 mm is full 135mm is low you can Google mm- inches....look at this link, https://www.google.com/#q=169mm+to+inches&safe=off. stick something down there that you feel comfortable with ....like an existing dipstick, or tranny dip stick, from another car or maybe a metal hanger that straight something that you feel comfortable with, and measure out 6.653in. Aka 6 2/3 inches aka 169mm..... just measure from the bottom of whatever you're using to your oil Mark and make sure it's that increment 169mm ...sorry for the rant blah blah blah blah
Wow Defiantly will do only concern is that if i don't tighten screw hard enough that it might leak. Today my warning sign showed up OIL LEVEL REDUCE OIL. I honestly don't think I have too much oil. Damn ik something is wrong with my oil sensor since my oil sensor told me to add 2 quarts of oil to reach Max level after I drain the oil from the main plug. Ughhh frustrations
I think your car is giving you the too much oil warning because you forgot to drain from the second plug. That left roughly a little bit more than a quart in the oil pan. So assuming you filled your car up with, say, 8.5 qts of oil, in reality you have 9.5 - 10 qts in the car. If I were you, I would just restart the process. Drain all the oil and buy new oil from Walmart. Drain from both plugs. Fill with 8.5 - 9 qts of oil.
I've never needed to put in more than 8.5 quartz.
Draining from both the plugs and then pouring in two jugs of 4 litres each which comes out to
8.5 quartz. I check the dash and it comes out good.
