Hiccup /p0102 and AFR
Old Feb 26, 2014 | 05:17 PM
  #76
Joncl's Avatar
E55
They went through oe and ec , they want to have renntech do the tune but they are very strict about buying hardware from them only to get their tune
Old Feb 27, 2014 | 06:08 PM
  #77
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Nope. I plan to have it tuned shortly, but it's because I know there's a ton of power left on the table via increased timing and leaner AF. The drivability is perfect as it is though.
Originally Posted by chiromikey
So you didn't retune after going from 82mm tb to the 90?
Old Feb 28, 2014 | 09:05 AM
  #78
jcjmw's Avatar
2005 E55 Wagon
200 miles on new tune and no hiccup / P0106.
Old Feb 28, 2014 | 11:27 AM
  #79
Denroll's Avatar
'06 E55
Do you have hills to drive up wherever you are in "West"?
Old Feb 28, 2014 | 11:34 AM
  #80
Joncl's Avatar
E55
Correct denroll, just roll into the throttle when going up the hill without making it kick down to downshift
Old Feb 28, 2014 | 05:30 PM
  #81
jcjmw's Avatar
2005 E55 Wagon
Yes. that is how my hiccup is triggered - in am to work and pm to home. But not so lately with BIP tune.
Old Feb 28, 2014 | 05:32 PM
  #82
jcjmw's Avatar
2005 E55 Wagon
I dont mean to be rude. But, I have to call bull**** on you. It seems to me that you have some other agenda or something and hoping that my hiccup /P0106 does not go away. If so, maybe you can start your own thread or something.
So far 230 miles, and no hiccup / P0106...after all kinds of driving, up/down, highway, bumper to bumper.
Old Feb 28, 2014 | 05:48 PM
  #83
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
well said JJ!!
Old Feb 28, 2014 | 07:49 PM
  #84
bstudey01's Avatar
2003 E55 AMG
I'm glad they got it sorted out for you!! I have been unable to get mine fixed, I see however that you have an 80mm TB, I have the 82 and actually think quite a few guys fixed their hiccup by just switching from the 82 down to an 80 so idk
Old Feb 28, 2014 | 08:57 PM
  #85
jcjmw's Avatar
2005 E55 Wagon
I had the 82tb, installled a new tune for it.......this is where my memory is fuzzy. I dont remember if I had this hiccup before the tune for the 82tb or if it came afterwards. I then switched back to the 80tb and reinstalled the tune for the 80tb but still had the problem. I am going to switch back to 82tb with BIP tune after 1k miles - assuming still no hiccup and p0106.
Old Feb 28, 2014 | 09:21 PM
  #86
bstudey01's Avatar
2003 E55 AMG
Interesting, be sure to let me know what happens with the 82. Mine started with the install of the 82 from 74 although I did injectors at the same time. For now I have just adjusted my driving style and it rarely happens to me any more, usually just step hard on the gas up the hill and it doesn't happen. Actually I dont really want to mess with the tune right now because it is dialed in perfectly with afr's and timing thanks to a 100 oct dyno tune. Thankfully I have a wide band installed so I can see when it happens and just pull over and do the restart to fix it.
Old Feb 28, 2014 | 10:50 PM
  #87
Joncl's Avatar
E55
Bs for what?
Denroll said it also is he bs too? Dude I hope it works out for you
Old Mar 1, 2014 | 07:50 AM
  #88
chawkins2001's Avatar
2006 E55 AMG
Jack, you should be fine at this point. Tony and I spoke about the mileage factor, and if it has been this long, and it comes back we would be more inclined to say it is a mechanical fault. We will continue to work with you should anything arise. Like I have said before, I have a 82mm, and never ever threw that code. A combination of a solid tune goes along way.
Hit me up or Tony if you have any further questions.
Old Mar 1, 2014 | 10:54 AM
  #89
jcjmw's Avatar
2005 E55 Wagon
Thanks.
Old Mar 18, 2014 | 11:32 AM
  #90
BI-Performance's Avatar
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
How is it going Jack?
Old Mar 19, 2014 | 01:24 AM
  #91
jcjmw's Avatar
2005 E55 Wagon
All good. No hiccup and no cel. I still have not had a chance to reset the fuel adaptations via star (to increase mpg). But, all good!!!
Old Mar 19, 2014 | 01:50 AM
  #92
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
How does this part work? I would be resetting mine daily if this is the case. This is non-intuitive. I would have thought adaptations would help mpg as it learns, not make it worse, or am I not thinking about this right?
... reset the fuel adaptations via star (to increase mpg).
Old Mar 19, 2014 | 08:35 AM
  #93
Great news brotha, thanks for the feedback.
Old Mar 24, 2014 | 08:42 AM
  #94
jcjmw's Avatar
2005 E55 Wagon
No more hiccup and no more P0106 CEL!!!! The only change is the new BIP tune. For those that said it is a tune related issue, well they were right....at least for me.
Old Mar 25, 2014 | 10:12 AM
  #95
2006 E55 AMG
Thanks for the update Jack, you da man
Old Mar 25, 2014 | 11:59 AM
  #96
ajm55's Avatar
2006 E55 AMG
Those with the hiccup issue should jump on this and have BIP resolve the issue for them. Whatever that may cost, it'll be a lot less than an engine rebuild when the motor pops
Old Mar 25, 2014 | 06:50 PM
  #97
Shifter's Avatar
E55, SL63, ML550
Are they 100% sure their tune will fix it? What if it doesn't ?
Old Mar 25, 2014 | 08:39 PM
  #98
ajm55's Avatar
2006 E55 AMG
Fair question. I would explore whether a mutually acceptable arrangemnt can be reached Weistec is looking into this in an effort to resolve the issue on my vehicle. Hopefully a fix will be found which can be guaranteed to customers
Old Mar 26, 2014 | 08:45 AM
  #99
2006 E55 AMG
Do you have the hiccup?
Old Mar 26, 2014 | 09:17 AM
  #100
Shifter's Avatar
E55, SL63, ML550
Yes I do.
