some questions about e55
first of all I am from Turkey and sorry for my english
seaarching and reading all the topics I can since bought my 03 e55 and now ant to start some upgrades.
first of all,
want to lower iat so ordered new bosch ic pump, but as I read it would be better with heat exchanger? which one should I buy? where to buy? will it fit directly instead of the original ic? or is it an extra unit to install?
other que, scoops? where to buy which to buy?
not possible to call a place, I should order, but ı dont know which one to order?
and last question for now
think that need a new torque converter, instead of that, is it ok to buy 3000 Stall Converter ?
thanks again, Ill be happy if you help me guys.
A lot of guys will use a larger H/E (Heat exchanger) to keep the intake air cooler, but other guys will do the "split cooling" mod (separates the H/E cooling circuit from the engine coolant) which is also said to help a lot. With split cooling, I think it is probably less important to replace the H/E since it is not dealing with as much heat..... The new H/Es replace the factory one, and are quite a bit larger. Some of them don't fit all that well and require modifications to the areas inside the bumper, and some hang down a bit lower than the original as well... you'll have to get some more opinions on which brand is best.
-G
other important problem,
if I need new torque converter, should I buy original one from MB for $2200? or stall converters from sellers are just fine?
Here I am with new problems
new problem is about very weak throttle response! and a engine fault lamp as well. its like driving 20hp car. and when I use elm327, saw that these 2 codes appearing.
