Kleemann Header install pics?
Old Feb 16, 2014 | 12:48 PM
Toadster's Avatar
2005 E55 AMG
Originally Posted by berti_00
+1
why you looking for gaskets. they came with gaskets nuts and all
LOL yes, you're right - I just checked the box
losing my mind today
Old Feb 16, 2014 | 01:05 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Originally Posted by Toadster
pics? or tips? where's the best weld spot?
Steering linkage has to be disconnected
Battery has to be disconnect since you are working close to the starter and alternator
Most hard bolt to get to is the passenger side lower ones by the alternator
Cut right after cats. Best thing to do is install headers and put the rear section in a truck and drive to an exhaust shop you can zip tie rear o2 for the drive
You will need the passenger side gasket to the resonator they always break
Old Feb 16, 2014 | 02:34 PM
MAN55LE's Avatar
04 E55 AMG
Definitely have an extra oxygen sensor bung welded in so that way you can log for a wideband later on without having to do any extra work..... ++++gear wrench!
Old Feb 16, 2014 | 05:37 PM
cal1's Avatar
SL55, ML500 & Acura TL
Originally Posted by MAN55LE
If you got it from Kleeman they come with in the packaging. gaskets, new brass nuts, referring to your two pictures the upper picture......thats you need if you were going to buy them individually, but they should come right in the packaging from Kleemann
It takes brass nuts to do the install? I guess that leaves me out.
Old Feb 16, 2014 | 05:58 PM
AMG E Power's Avatar
E55 amg
Just Pay 4-500 bucks to have it done save yourself a headache
Old Feb 16, 2014 | 06:36 PM
cal1's Avatar
Good advice.
I actually have Kleemannesk shorty headers on my SL. They came from EvoSport though. And yes, I paid for the install.
Old Feb 16, 2014 | 10:54 PM
  #32
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
+1 on the O2 sensor bungs … but why are you pulling the headers to put in the bungs? just disconnect after headers and drill holes in the down pipe area, start the engine after install to blow the shavings out and listen to the loud headers.
Old Feb 17, 2014 | 12:13 AM
  #33
MAN55LE's Avatar
04 E55 AMG
I was told the bung needed to be 12in from the last bank and try to keep the sensor vertical... I bought two sensors for each side ....gunna do it with the meth and zt2 blah blah blah
Old Feb 17, 2014 | 11:27 AM
  #34
Toadster's Avatar
2005 E55 AMG
That's what I'm doing - but I don't think he's done the Kleemans before so trying to get some reference pics
Old Feb 17, 2014 | 11:54 AM
  #35
turbo97se's Avatar
Well ... I have installed them further away than that with no issues. 18"-24" or so Just make sure they are not lower than 3 O'clock position in the pipe.
Old Feb 17, 2014 | 09:34 PM
  #36
999turbo's Avatar
2005 e55 amg
Got my kleemans headers for valentines Day so I'm going to do my install soon.Was wondering if I should eliminate cats and resonators?
Old Feb 18, 2014 | 09:54 PM
  #37
Toadster's Avatar
2005 E55 AMG
probably a simpler install to just go straight back from the headers to the resonator, not sure if you want to pull the resonator if you're also pulling the 2ndary cats - you'll be awful loud and drone...
Old Feb 18, 2014 | 11:58 PM
  #38
Toadster's Avatar
2005 E55 AMG
what if i'd want to put back to stock someday? still cut right after the primaries? also, how loud is the car when you drive to the muffler shop?
Old Feb 19, 2014 | 06:29 AM
  #39
999turbo's Avatar
2005 e55 amg
What should I do if the car only has the primary's?Should I leave them or take them out?Also why does everyone put in a X pipe instead of straight pipe?
Old Feb 19, 2014 | 09:43 AM
  #40
Toadster's Avatar
2005 E55 AMG
you have to remove the primaries to install kleemans - x-pipe helps to scavenge exhaust air and optimises air flow between the exhaust banks and can promote a few extra HP - straight pipe works as well but louder than x-pipe (usually)
Old Feb 19, 2014 | 10:56 AM
  #41
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
I see everyone reusing the studs, why not order more from Mercedes? When I installed the headers in my M3 everyone recommended using new studs when they came out
Old Feb 19, 2014 | 11:32 AM
  #42
berti_00's Avatar
2016 Cls63s AMG
i used all new
Old Feb 19, 2014 | 11:57 AM
  #43
55fanatic's Avatar
i used all new
this man knows whats up, why dick around with the old ones when you just put the new ones in before the headers go in.
Old Feb 19, 2014 | 12:13 PM
  #44
turbo97se's Avatar
I said around post 8 or 9 that I replaced everything.... Toad, I used to worry about going back to stock all the time. Not a single one of my cars has ever made it back to stock
Old Feb 19, 2014 | 12:16 PM
  #45
E55Greasemonkey's Avatar
This place is a joke.
Done yet? You've spent more time posting than it takes to do the job. Get 'er done!
Old Feb 19, 2014 | 12:40 PM
  #46
E55 amg
seriously
Old Feb 19, 2014 | 12:49 PM
  #47
55fanatic's Avatar
my apologies... this man knows whats up too...
its true toadster fashion... hem and hawing more than the labor involved to do something
Old Feb 19, 2014 | 02:48 PM
  #48
turbo97se's Avatar
That's better! ... LOL
Time to get 'er done Toadster ... save your fingers for loosening and tightening those nuts ... referring to the ones on the headers!
Old Feb 19, 2014 | 02:59 PM
  #49
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Toad, install it after you do your registration/smog. It will last other 2 years...
Old Feb 19, 2014 | 03:11 PM
  #50
Toadster's Avatar
2005 E55 AMG
yup, got smogged in December - my primary tech is moving to Texas...
so I have a referral to a new guy but he's never seen the Kleeman setup - just looking for photos for a setup including the 2ndardy cats......
