Dashdaq TPS help
https://mbworld.org/forums/attachmen...-diagram-4.pdf
https://mbworld.org/forums/e-class-w...les-chart.html
. I can see the TPS signaling changing when I press the throttle. It's just that Dashdaq reads 100% when my foot is only at ~30%. There is usually some kind of calibration and I don't see it. I am sure it is something simple I am missing.https://mbworld.org/forums/attachmen...-diagram-4.pdf
It happened to 2 people I know, try this when the car is on and you see the tps jumping like you said, leave the car running and disconnect the power supply going to zt2 ( the black plastic with all the wires running from it) and replug it all while with the engine on if it fixes then you have constant power going to the zt2 instead of only key power, if that the case rewire for key power only and it will work
So I threw it on the DAS
My issue is as follows.
When Gas pedal is at rest, you can see that pedal is at 0.3V and Throttle is at 1 V, which is ok.
When I press the pedal about 30%, you can see below that the pedal sensor is at 1.4V, but the Throttle Position sensor is maxing out at 4.3V. Does anyone know what is going on here? I do not have the car running during this particular test, but I believe the same happens when I have the car idling. any thoughts?
