e55 fuel filter myth revealed
Old Feb 18, 2014 | 12:15 PM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
Originally Posted by GunMoto
As Craig mentioned, we can consider running the OEM sender unit without the internal pleated filter, and instead, run an aftermarket external inline filter on the output side of this OEM sender unit.
EDIT: Using an aftermarket inline fuel filter will allow easy/straightforward replacement at service intervals.
Of course, this is a separate issue from the fuel sender leaking. The top half is still prone to cracking, resulting in fuel puddling on top.
Dealing with this currently; Of course, this is a separate issue from the fuel sender leaking. The top half is still prone to cracking, resulting in fuel puddling on top.[/QUOTE]
Indy wants $1,800 to fix and I'm taking it to the dealership tonight to see if they will good faith ALL or some of the repairs. FINGERS CROSSED!
Old Feb 18, 2014 | 12:42 PM
320 dreamer's Avatar
2003 porsche 996 turbo
craig drop by the shop an look at the weldon pre filter and post filters thqats going onto my car. may be what your looking for. washable an fittings and mine are an8 but many sizes available. my pre filter is a 75 micron and the post filters are 40 micron
Old Feb 18, 2014 | 01:00 PM
GregMB's Avatar
Picking up my car tomorrow from the dealer.... (2006 E55 w/~ 47,000 miles)
SA indicated that only the DS was leaking, but then when they went to do the swap, they ended up breaking off the fitting on the PS unit, so that had to be replaced as well. Normally I'd be pissed, but my warranty covered the entire bill on this one ($1100+)
The best news is that since this was a 3rd party warranty, they don't care about getting the old parts back. So I told them to save me all of the parts so I can take them home with me. I fully intend to perform some detailed "Failure Analysis" on these parts and post up my findings....
FWIW: My fuel leak first appeared back in Sept 2012, when the car only had 36,100 original miles on it. That's FAR too early for a fuel filter to be blamed for the leak.... IMHO. I've been playing the "3/4-Tank Fillup Game" ever since.
My Original Thread is here:
https://mbworld.org/forums/w211-amg/...complaint.html
It shouldn't take long to prove/disprove hairline cracking of the white plastic area.... some simple dye or even colored water should reveal where the leaks are actually originating from and I will bet money is NOT from the O-Rings themselves.
In the meantime, I absolutely plan to flood my new replacement parts with a fuel-resistant epoxy to increase the overall strength and thickness of those parts.... even the "newest" design parts are prone to leakage, so new parts don't actually FIX the issue.... they simply reset the clock and give you a couple more years before having to deal with this issue again.
-G
Old Feb 18, 2014 | 01:16 PM
chawkins2001's Avatar
2006 E55 AMG
I was there yesterday but all I need to know is our fuel line size. I few people have replied via text, but I have three different answers
This is the filter I am leaning towards if our line is a ~6an:
http://www.summitracing.com/parts/rus-650140/overview/
Stainless mesh at 40 micro is recommended for my E85 system, washable and perfect for inline duty.
Old Feb 18, 2014 | 01:31 PM
Denroll's Avatar
'06 E55
If someone is going to do their filter soon, you should (in the name of science!) take some fuel pressure readings before and after swapping out the filter. The clean filter readings would give us a good baseline to see if any aftermarket fixes are better or worse.
Old Feb 18, 2014 | 01:37 PM
GregMB's Avatar
Is fuel pressure a "loggable" item with DashDAQ or OBD-II, or does that require adding extra sensors/wiring to accomplish???
-G
Old Feb 18, 2014 | 01:42 PM
  #32
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
isn't there an aftermarket alternative that could replace all the headaches in the tank? Someone CNC a carrier for some pumps, throw the filter on outside of the tank, and lets be done with all these fuel leaks
Old Feb 18, 2014 | 01:44 PM
  #33
2006 E55 AMG
I have a fuel pressure port on my fuel rail and will do that just for you homey
BTW, I just picked up a trailer hitch that had a 6" rise, then got a ball with a 1" additional rise so 7" total, lmfao
Old Feb 18, 2014 | 02:19 PM
  #34
saleen01's Avatar
2004 E55
someone should develop an inline system using aeromtive parts or equivalent.
cant be that hard.
Old Feb 18, 2014 | 02:38 PM
  #35
rockthemullet's Avatar
2005 Mercedes E55 AMG
It's a little more complicated than that since we have a humped tank with a venturi setup from one end to the other. It would require two carriers and some fancy routing... considering this is something probably a dozen or less people would be into, the business case just isn't there.
Old Feb 18, 2014 | 02:50 PM
  #36
DGSU4EA70's Avatar
2005 E55 (FST N OC)
-G
I also have joined the crew that only fills the tank 3/4 to help this issue until resolved and it seems to be working. This will be my temporary fix until I can afford to get this done by Indy or Dealership. I filed my complaint with the NHTSA (ODI #10563405) as well on 02-07-14. Every member here who has not filed a complaint already should as we are stronger in numbers! I am hoping the 2 gents pursuing a lawsuit against MBUSA for this issue at the least get MB to recognize that this issue poses an obvious DANGER to those driving these vehicles and those around us. I am driving a 2005 w/72k miles.
Old Mar 23, 2014 | 11:41 PM
  #37
jcjmw's Avatar
2005 E55 Wagon
Just following up. Any updates?
Old Mar 24, 2014 | 05:40 AM
  #38
june82000's Avatar
'05 E55
I'm curious just what you mean by a dozen or less people...
Old Mar 24, 2014 | 11:11 AM
  #39
2006 E55 AMG
I had to deal with a couple other issues first jack, but now that is out the way, I will attempt it pretty soon.
Old Mar 25, 2014 | 12:42 AM
  #40
boostiality's Avatar
2004 E55
Chawkins: that trailer hitch is badass! Just looks trippy on sports cars/sports sedans.
Old Mar 25, 2014 | 12:51 AM
  #41
thunderclaps's Avatar
E55 AMG, 04STI, 07GTI, 05 HAYABUSA, 05 GSX1000
This is how I use my hitch.
Attached Thumbnails e55 fuel filter myth revealed-20140214_123144.jpg   e55 fuel filter myth revealed-20140215_074114.jpg
Old Apr 22, 2014 | 03:11 AM
  #42
jcjmw's Avatar
2005 E55 Wagon
Chawkins, any updates?
Old Apr 22, 2014 | 08:39 AM
  #43
How many people have actually replaced their fuel pumps themselves? I see owners often taking the car to the dealership... and I'm confident a dealership is likely to turn down a modification job like that.
To mimic the stock system with the venturi would actually be quite difficult without a lot of R&D, it's not just a fuel pump attached to a stick down there.
Old Apr 22, 2014 | 08:48 AM
  #44
2006 E55 AMG
Not yet, I will let you know once I install the inline and get rid of the paper filter.
Old Apr 22, 2014 | 10:15 AM
  #45
Gadget's Avatar
06 E55 AMG, 13 C63 AMG
It is not hard to replace yourself at all.
You will need the special tool and clamp to reclamp the high pressure line once done.
I did mine in about 30 minutes, both sides.
G
Old Apr 22, 2014 | 11:14 AM
  #46
Miniac's Avatar
E55 AMG
Which special tool are you talking about Gadget?
Old Apr 22, 2014 | 11:24 AM
  #47
Gadget's Avatar
The fancy clamp crimping pliers for the German style hose clamps.
G
Old Apr 22, 2014 | 12:30 PM
  #48
Miniac's Avatar
E55 AMG
Oh that thing gotcha.
Old May 25, 2014 | 08:30 PM
  #49
BC928's Avatar
2006 E55, Various other German and ‘Murican
Any more pics of these stock pieces?
Old Jun 2, 2014 | 05:18 AM
  #50
austingtir's Avatar
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
Id like to sort this filter situation out. Its totally ridiculous that we are in this situation where we have to buy a complete housing. This is the closest I have found to the size of the factory one as measured in imperial by OP. Its a bit out on dimensions and style of filter....
http://www.inlinefilters.co.uk/Filte...und/FFR-C11859
That company reckons they can supply it if we can get the part no of the stock filter which probably is not possible....
I have contacted VDO siemens to see what info i get out of them.... not having much hope though.
Some outfit out there must make something thats close enough to a drop in.
