e55 fuel filter myth revealed
Our fuel filters are not in fact one and the same with the sender unit. The filter pops right out after you pop off the top of the sender unit.
I also took some measurements of the little bugger to see if they are any aftermarket replacements. I am going to buy a stainless 10 micro mesh washable filter for my e85 setup from Division X (GT500 vendor) and run it inline. Not quite sure if removing the stock filter in the unit will cause some electronic issues, but only time will tell.
There is no actual part number on the fuel filter itself as a fyi.
May find aftermarket filter from K&N or AFE or bikes filters or any other car models, that can matching
the filter measurement spec....?!?
ZAYED,,
EDIT: Using an aftermarket inline fuel filter will allow easy/straightforward replacement at service intervals.
Of course, this is a separate issue from the fuel sender leaking. The top half is still prone to cracking, resulting in fuel puddling on top.
Now, if you and or BIP comes up with a replacement filter (in OEM location) or an inline filter that makes it a lot easier to change.....that would be spectacular!!!
If one can change the filters I doubt the pumps would over heat and crack.
Can post up some accurate measurements in mm? The holes in the top and bottom and the width and height?
My Nissan Navara oil filter looks very similar just bigger holes on inlet and outlet.
The plastic on both the driver & passenger side parts are really brittle/fragile. It never seemed up to the task...
Definitely makes sense to convert to a more traditional externally-accessible fuel filter.....and based on how filthy they always seem to be in these photos, change them a LOT more frequently than 60K miles!
-G
This one had about 100K miles on it lol.
