In a thread on the W211 forum there is mention of an update that enables you to see the suspension settings on the dash. Can anyone see this ? If so where and how.
Quote:
u have a w211 though right? also, it depends when your car was built. im not sure when the W211 E55's were built, but if it was a late 03, then when u select the sus setting it should show, and if you leave your moon roof open it will tell you. GLOriginally posted by Eddie Knopp
I have a late Sept build '04 E55. It does tell me when the roof is open (when I turn off the car).
Where and when does it tell you what the suspension setting is ?
When you push the suspension button to toggle between comfort, sport I and sport II. It'll show you on the dash. Also when you raise your car it'll show. I'm pretty sure your car will have this feature as it was built around the same time as mine.
Thanks Norb - Where does it show up ? I'm going to try it out later. Also does it stay displayed ?
It shows up in the speedo, it only lasts a few seconds and then it goes back to the default display.
Thanks much Norb !
Norb -
Just as you said. I guess I was assuming that it was always visible like the tranny mode.
We need to start the NorbFAQ.com so that he can spend more time with his family and less time clue-ing us in!
