No Longer stock!!!
I don't think anyone is doubting you, or attacking you personally.
We are doubting the operator of the dyno and whether he knew what he was doing when dynoing. The type of dyno and gear you dyno in is a HUGE factor as well. A lean mixture will absolutely spike that torque much more so than what it really is.
As long as you're happy, that's all that matters!
Just gotta make sure things aren't skewed
Exactly. I'm just trying to wrap my head around the data that was posted.....
No headers, no cooling..... just an S/C pulley and tune for 618TQ? It just stretches the limits of reason.
As mentioned, there are only a handful of guys pushing over 600TQ, and they are running enormous crank pulleys (and loads of other mods) to do it.... and those guys are also somewhere north of 540WHP too. That's what seems so odd about your final numbers.... the peak HP should be a lot higher for the kind of torque that is being claimed. That's why I was wondering about being in a lower gear. 4th is 1:1, but 3rd is 1.41:1 you get quite a bit of extra torque multiplication from the lower gear which is what motivated me to ask the question....
-G
after your all set and done at that shop take it to a different dyno and see
Currently running nothing more than a set of MBH longtubes & an EC box tune. It will be good to get a baseline run or two on that setup, before adding the 172 pulley & Kleemann tune this spring.
I believe you're right about the MPH at the track. Even if you blow the launch, the 60' and the RT..... The MPH should still tell you a lot about the power you are making.
-G
After a little research I found some info on the audi forums and google that Bren Tuning collaborates with OE Tuning for their tunes.
Do you guys think OE Tuning sends Bren tuning a tune and maybe they tweak it a little???
-G
A couple years ago MBH ran a group buy on their headers, so I ended up getting those a long time ago. I did all my research and knew the parts list I wanted, so over time I've been slowly acquiring the pieces.... Shardul just hooked me up with a custom 172mm crank pulley. That plus a quality tune puts me at 500WHP, which has always been my goal. Pretty conservative for an E55 by today's standards.
PLM H/E is the final item to buy.... Then I need to get a huge pile of parts installed.
-G
