Voltage issues
I will agree the charger is rather small, I can charge up the auxiliary battery but that takes the full 10-12 hours to charge that small battery, I am imagining that the main will take a couple of days on that charger.
I will do some more reading and update this thread, if nothing else, this wil help someone else in my shoes.
New alternator (Bosch) ordered. Am I being cheap buying a new unit online for 300 vs OEM for 700? I hope this doesn't bite me in the behind like the first so called bosch reman did
I would still get an amp gage on the output of that new alternator just to confirm your dose not have any extradnornary high amperage load on it, you see, in this case the high load was most likley your OEM battery.
It might be good to monitor your voltage for the next few days too.
FWIW this makea a case to buy new parts.
I just don't know how it passed bench tests though
Happy Motoring now.
Don't worry.
I know the signs of a bad battery.
I just had it load tested.
(Of course all this mentioning of it will likely cause it to fail out of spite!)
Live in the cold (gives longer battery life) and also garage the car most of the time.
