Struggling to find info after extensive research, but at what RPMS does a stock w211 e55 amg cruise at 60mph.
After doing short tubes, new motor mounts and trans fluid and filter flush and change im now cruising 60mph at 1950rpms? Mods in signature also. Seems like rpms have gone up a little. Im relatively sure the needle would sit around 1500rpms at 60mph prior to the work done above
Sounds like your torque converter is not locking up. But that is just a guess.
your changes would not affect the gear ratios - rpm will be the same as it was at cruising speed top gear
