ESP Malfunction
Old Mar 17, 2014 | 09:06 PM
danil_karmiev's Avatar
E55 AMG
ESP Malfunction
Came back from vacation, noticted a msg ESP MALFUNCTION VISIT WORK SHOP. What could be the reason? Solutions? Help
Old Mar 17, 2014 | 09:17 PM
E55 AMG
2004 E55 AMG
Old Mar 17, 2014 | 09:48 PM
berti_00's Avatar
2016 Cls63s AMG
Check your throttle body
Old Mar 17, 2014 | 10:22 PM
byronburns's Avatar
2003 sl55
possible solution
My light was on my sl also. I connected it to the star das. it stated that it didn't recognize steering angle. the solution? turn the wheel from lock to lock. It worked for me. good luck.
Old Mar 17, 2014 | 11:18 PM
SheriffDep's Avatar
13' E350 4matic, 08' E63
I had this issue with my 07 E350, next day went away, and was gone for three months. then came back on for two hours. Season weather change did it every time. Codes in comp showed low voltage, or irreg voltage. Hot texas sun and cold likely had battery a little low, and the front batt was original. Could be setting it off.
Old Mar 18, 2014 | 01:51 AM
E55 AMG
It went away on me too, just drove it, slow or fast, it doesnt come up. I turned the wheel left and right when i started it. I guess it helped. Thanks guys
Old Mar 18, 2014 | 11:52 AM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
Just for future reference, I had to change out my clock spring when mine was doing this. Same symptoms, it would go away sometimes and was not predictable when it would come on although it was frequently. Changed that and the steering angle sensor while in there and hasn't been back since. Good luck.
Old Mar 18, 2014 | 02:41 PM
E55 AMG
It went on again, my allighment isnt done right. Benz dealer told me
