SL55 bypass valve v SRT6/SLK32 no bypass.....
Old Mar 26, 2014 | 04:28 PM
Billy22Bob's Avatar
R170 99SLK230 + SLK32
Can someone explain (or post a link/s) as to the differences between the 2?
The bypass valve (2ndry throttle body) in the SL55 sits just after the primary throttle body and allows air to bypass the supercharger.
I presume it's open somewhat unless your under WOT or at least if the MAP pressure starts to go positive....
I've noticed from logging on on my SLK32, that my MAP (pressure) doesn't go +ve unless I'm over 3,000rpm and/or throttle position >25%.
Just wondering if there is any deficiency in not having a bypass on the supercharged 3.2L?
Attached Thumbnails SL55 bypass valve v SRT6/SLK32 no bypass.....-mapvrpm-throttle.jpg
Old Mar 26, 2014 | 04:55 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
There are a few threads that discuss the by-pass valve here on MBWorld, as I recall MB added it to reduce a "supercharger Lope". The first SL 55s had no bypass and suffered a harsh SC engagement and poor idle.
One member here did mod the by-pass valve to log/see the position of the BPV you can search for him under the name Finny "stock to awe"
I really dont think the V6K suffers any loss by not having a BPV.
Old Mar 26, 2014 | 05:20 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
since the boost / forced induction is generated after the throttle body the BOV is not that vital as it would be on turbo cars. I could be wrong.
Old Mar 26, 2014 | 05:48 PM
Billy22Bob's Avatar
tah
https://mbworld.org/forums/w211-amg/...stock-awe.html
b22b
and an Aussie to boot!
Old Mar 26, 2014 | 05:55 PM
shardul's Avatar
http://www.eng-tips.com/viewthread.cfm?qid=233418
Old Mar 26, 2014 | 08:42 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
The supercharged 55 engines use a bypass valve. It is very much necessary. It allows the car to run as if it was a NA car when you aren't on boost by allowing the air to bypass the supercharger. Without it, the car gets crappy mileage and runs hotter. The heat is much less since the car has an electronic supercharger clutch but the bypass valve really makes it a much nicer engine to live with on a daily basis. You can really feel when the bypass valve fails or the vacuum to it is lost.
