••• Project Stock to Awe •••
Decided to pull the drive line out for some work. I needed to do a lot of small things like fix the freekin sump oil leek which happened just after warranty, typical.. so it was easier to just pull the whole lot out.
I'll keep posting photos as I progress.
Currently waiting on some parts from the fatherland and the heads to be returned from the local race car guru. (Eddie Woods director of HSD Cylinder Heads) I'll take a stack of shots of his handy work when they get back as this guy is in high demand.
As you can see the headers came up beautiful after Jet-Hot coatings did their stuff. I had the stock 50mm inlet of the primary cats cut off and replaced it with a 4 bolt 70mm plate to remove the bottle neck. The secondaries and the long resonator get the chop chop too.
More later...
More later...
More shots...
Cool gauges, the red one is air/fuel and the blue one is Vac and boost in one.
SLR cam sensor problem solved with two air conditioner line O rings. (Green)
Oil leek...
Oil leek...
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
finny- do you think the carbon build up from the pvc can be avoided with the canister setup vruss was setting up on his car?
The catch can Victor is using is the best I've seen so far.
2007 S65, 2005 Nissan Armada
Cool post, looks like a fun project!
I can't believe the size of the tranny that thing is huge, on the pic of the rod cap where is the joint I don't see it?
none
Agreed!! Once you remove these parts and put this much work into them I could never reinstall the PCV as is, knowing it will tarnish and gum up all my work. I remove a ton of crap about every two weeks with my catch setup.
Ausies can register Euro plates here too. Had these made in Heidelberg for 12 euro. Just looks different here.
2003 E55
Finny, will AC o-rings cope with the heat and oil? I would think they're manufactured for a different operating environment. I would hate to have them prematurely fail after all this hard work.
Keep up the photos..... they make me scared.
