Front suspension clanking noise when cold, car pulls to the right...
So, it leads me to believe that its either the top of the air strut where it mounts to the car , or the inside of the air strut itself. I have the same issue, that I'll typically hear the noise more so in the colder months. Annoying, but at this point the strut is working so I'm not inclined to change it, at least not right now.
Countless alignments
New front end parts
New tires continental (have been rotated all possible ways)
Front strus = MB bilstein remans
Rear struts = Arnott
Multiple level calibrations trying different variations
****in drives me nuts
is sitting on... There 3 ball joints on it or bushing they might be doing the clunking...especially the one that the swaybar end long is attached to..
UPDATE: Found the problem. The rattle slowly got worse. We replaced the link arms between the sway bar and suspension but wasn't the problem. Had another look and found that the front RH brake caliper was loose. The bolts are lock tighted so were still tight but the caliper was loose. Cranked the bolts up tight and the rattle ceased. I only discovered the loose caliper by turning the disc backwards and forwards and heard a clunking. I first thought it was the disc pads moving but found it was the whole caliper. Checked all the other callipers and they were tight.
One problem I've noticed with it is that when the car is cold there is a clanking sound from the front suspension when going over bumps and uneven surfaces at low speeds. It disappears after I've driven the car for a while and also at speeds over 35-40MPH.
The other issue is that generally the car pulls to the right at speeds under 70MPH. Yes, it's intermittent but it happens about 85-90% of the time on smooth roads. The car just had an alignment when I purchased it and I asked for a print out which looked really good.
After a decent amount of searching I had my shop tighten the bearings then replaced the front sway bar drop links, followed by upper and lower ball joints. Upon visual inspection after removal the old parts were still good (car has 80K miles on it). Then had another alignment. But the suspension refresh did not help - the noise is still there, and the car still pulls to the right.
At this point the only possible culprit would be the air suspension. Has anyone else experienced that? I would rather not have to go through the trouble of replacing the air springs unless I absolutely have to.
Thanks!
